928 Forum 1978-1995
Sponsored by: 928 Specialists
Andrew's 91GT Engine Thread
Old 02-25-2008, 12:15 PM
  #286
69gaugeman
69gaugeman's Avatar
The seal sees a relatively high surface speed (large diameter). The old seal will actually 'machine' a groove into the shaft. The new seal very likely will not sit at the exact same spot. If the shaft is not polished smooth and the scratch lines go the wrong way it can actually work like a pump and force oil out the seal.
In fact many auto manufacturers dictate the direction and angle the grooves can have, as well as the roughness.
Old 02-25-2008, 12:58 PM
  #287
Bill Ball
Under the Lift
Bill Ball's Avatar
Originally Posted by Andrew Olson
Yesterday I was able to tkae the car out for its first drive. Everything seems to work. No traction until 3rd!
However, the friggen oil pan is leaking (yes I have a REAL Gasket on there) and it appears the RMS is also leaking - the lower BH cover has oil dripping from it , so I suppose it could be the oil pan back there. MFer!
When the RMS leaks, it will get on the rear of the oil pan and make it look like the pan is leaking as well. Since the RMS is easier to do with the engine in the car, I hope that's all it is. That being said, if the pan gasket is new, then it is more likely to be the problem. I do have a leak at the rear of the pan with a new silicone gasket on a car I worked on. I must have screwed up installing it.
You'll need to pull the lower bellhousing cover and see if you find oil behind the flywheel.
Old 02-26-2008, 10:36 AM
  #288
Tony
Tony's Avatar
Driving on the ice agian Andrew?
Old 02-26-2008, 11:24 AM
  #289
Ninespub
Ninespub's Avatar
YEA! Congrats Andrew! I'm looking forward to the same experience again someday myself. Enjoy Germany.
Paul Barrera
Old 02-26-2008, 11:33 AM
  #290
Jim R.
Jim R.'s Avatar
More like a self generated oil slick!
Jim
Old 02-26-2008, 12:02 PM
  #291
DR
Rennlist Sponsor
DR's Avatar
Jim
I think you and Tony or both wrong.. I have been trying for years to get Andrew to get some wider tires, but he really loves those 185/75-14 tires he has on the rear.... and for some reason he thinks the whitewalls are dope!
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old 02-26-2008, 12:20 PM
  #292
DonT
DonT's Avatar
David -
Those thin whitewalls are a little too spiffy. How about WIDE whitewalls - 165/80/15?
Old 02-26-2008, 12:25 PM
  #293
DR
Rennlist Sponsor
DR's Avatar
Originally Posted by DonT
David -
OH Nooooo! Please delete that before Andrew sees them!
I will be very embarassed seeing Andrew's 928 with those at SITM!
Old 02-26-2008, 06:49 PM
  #294
FlyingDog
FlyingDog's Avatar
A pic of Andrew's track car...
Old 02-26-2008, 06:55 PM
  #295
DR
Rennlist Sponsor
DR's Avatar
Boy are we gonna catch it when he gets back from Germany Friday... HEY, we still got 3 days left ... PILE IT ON !!!!
Old 02-26-2008, 07:11 PM
  #296
DonT
DonT's Avatar
Andrew's latest project.
Old 02-27-2008, 11:25 AM
  #297
AO
Supercharged
AO's Avatar
The interweb is accessible even from Germany! Why I oughta...
Old 02-27-2008, 11:36 AM
  #298
RyanPerrella
RyanPerrella's Avatar
GO TO BERLIN!
Best city in Germany!
Old 02-27-2008, 11:59 AM
  #299
AO
Supercharged
AO's Avatar
I'm in Koblenz right now Where the Rhein and the Mosel rivers meet. Off to Stuttgart tomorrow.
Old 02-27-2008, 01:58 PM
  #300
BC
BC's Avatar
Originally Posted by RyanPerrella
GO TO BERLIN!
Except for in February, and in the coldest winter in recent years.
Quick Reply: Andrew's 91GT Engine Thread
