Who's got the coolest wheels? (gimme pix!)
#1246
Good deal. My Mille Miglia fronts are collecting dust in the garage - they're in serious need of straightening/refinishing/new tires. Check out the bend in the one on the right at about the 1 to 2 o'clock position:
#1248
Oh, and let's show the D90s some love in this thread:
#1249
That car is stunning indeed.
I'm thinking about the same wheels. Are those 18x10 and 18x8?
Offset?
QUOTE=JWise;12829205]Thanks Pete! Here's boomboom's car from the 2009 OCIC, back when Marc W still owned it. It was sporting 18" 996 Carrera wheels at the time. The Zyclamrot Metallic was/is stunning, indeed.
[/QUOTE]
Offset?
[/QUOTE]
#1250
The oldest Strosek car Version II, the marine-blue Strosek Version III and the red Strosek Ultra. The oldest car has 16" wheels, 10" wide at the rear. The other two cars have 17" wheels, 13" wide at the rear.
Åke
Åke
#1251
Edit: Ok, I just verified and they are 8 and 10 and 50 front and 65 rear. From the pictures of these on this thread It looks to me like the 50 front offset is just about the limit for the 928, and even those look outside a tiny bit.
#1252
I just bought a set of these on eBay for $750 including nearly new Goodyear tires in the correct size for the 928. They are 18 by 8 and by 10. I think the offset is ET50 front and ET65 rears, but I haven't verified yet until I get the last package and open them. The rears may require a spacer, but I just got the longer studs from 928 Int'l for that if needed.
I always get the Carrera LW and the Carrera III wheels confused, but the one that looks like these but without the pointed spoke has a much better front offset for the 928. I think it's a 58 or 60. That 8" with 50 offset wheel is for the front of a 911. The Panamera wheel looks similar too and has a good offset.
#1253
I just looked at these wheels and see that there is quite a bit of "meat" between the bottom of the lug hole and the face of the mounting surface, more than I recall seeing on some others, like my Cups, so I'm thinking I might be able to take off about 3mm there. Then I think I'll look at the front hubs and see if any material might be taken off of those on either side. If I could get another 5 or 6mm off those that would put these right where they need to be, at least form an appearance and clearance standpoint. It would be nice to get closer to the ideal 65 however.
#1254
Here's my car with Cayman S wheels:
18x8 and 57mm offset with 245/40/18 tires in front
18x9 and 43mm offset with 275/35/18 tires in back
The fronts rub on large bumps so are too wide. (Actually just one side but that's my special car.) I'm going to add S4 upper arms for more camber and that should bring the wheel in the needed 1/4".
The rears fill the arch completely.
First post...
Been busy choosing a color for my soon to build 928... What color is this on the first pic? Nutmeg? Or Mocha? Or is it something else?
Oh, and the second pic is just for fun...
#1257
