The Twin Screw Thread
#706
Originally Posted by mspiegle
Are you guys sure that your PS pullies are on the right way? I think there's 2 ways to put it on (backwards and not backwards)
i've seen the issue where it can be incredibly close to the rad hose. As said earlier, the 85/86 hose fixes this. Are you guys saying that the belt is skipping forward on the pulley closer to the rad hose?
#707
Under the Lift
Yes, Mike, the belt moved forward such that 2-3 ribs are off the front of the pulley. Mine did it and so did Seth's. A spacer largely fixed it.
#708
I run ribbed belts on my PS and Airpump pulleys. However, they do not walk out for whatever reason... I am using the setup I bought from Delta P, as the crank pulley also has a 6 rib blower drive in 7 inch dia... It's hard anodized black, and has been on the car for 1-2 yrears with no problems..
HTH,
HTH,
#709
or the other way?
#710
I *think* its flat-side out, but I really don't remember, I'll mention something here when I get home. I also owe the thread some pics of how the pullies/belts are setup. I just simply haven't had a belt walk or become "chewed" up due to any alignment issues (7-8K miles daily driving and the belts have never needed to be changed).
#711
Under the Lift
Yeah, mine is flat side front. Thanks for any follow-up, Mike. I've had minimal problems since I put in a spacer to put the pulley a little more foward.
#713
I also found that if you zip tie the fan shroud to the little rubber/metal pieces on top that the radiator "floats" in, you can get a little tension and keep the radiator about a half inch closer to the front of the car, which also gives more room for comfort.
#714
Get an 85-86 radiator hose for problem 1
I drove from SF to Sacramento with PS
I drove from Sacramento to Portland Oregon with no PS, it's a problem but can be remedied by adding a spacer.
Originally Posted by Cameron
I have the rad hose zip tied to the fan shroud, so it is somewhat out of the way. It the belt walks all the way out, it still may nick the rad hose, or at the very least it will fall off leaving me without power steering.
No one else has this problem?
#715
I am at work and can't go to the car and measure right now, but Sab and I are doing some pulley research. Anyone know the outside diameter of the power steering pump pulley in the Andy Keel set up? We are looking at getting some made with inner and outer lips to stop the belt walking issue.
Thanks,
Thanks,
#716
Also, does anyone know what diameter a 8PSI SC pulley would have to be?
Is anyone selling these pulleys or should I get the SC pulley made as well?
Thanks,
Thanks,
#717
Thanks,
Thanks,
#718
HTH,
HTH,
#719
In the front of the pulley, yes it is. In the back not. Since the belt for some unexplainable reason at times starts to wonder off in either direction, it would be better to make a pulley that forces the belt to to stay put.
#720
