The Twin Screw Thread
#2386
AO-
Congrats again on those numbers. I think getting the pump working will certainly push into the 500's.
Speaking of which I have a very affordable tank guy, so if you want to collaborate on getting some paper/cardboard mockup made for one to fit in the drivers-side under headlight void, I can get them popped out. I have speculated for years that running a detergent though those intercooler pumps would cause premature failure. Also, alcohol is an oxidant for untreated aluminum so could cause some buildup in the system further contributing to pump failure.
I can start working on some mockups this week and send you files to make your own cardboard mockup for test fit, and we could get these popped out next week or so. I think I also have a nice Jabsco pump laying around somewhere if I can find it.
Hans
Hans
#2387
Supercharged
AO-
Hans
Hans
Yeah. I'd totally be interested in that. Let's do it. What do you need from me? We need to make it accommodate the ABS pump of the late cars, but also make sure it works on the early cars.
How much volume do we need? I guess as long as the heat exchanger can bring it down to ambient, it doesn't matter much.
#2388
I would like to see at least a gallon, but we can go with as large as will fit. I can use the GTS I have in the driveway as a mockup. I dont have easy access to an early car though, so you will have to take the model and check it against your euro. I will try and start work on Wednesday evening on the templates.
Hans
Hans
#2389
Thanks guys. It's amazing how hard the car pulls. I try to be gentle just so I don't spin the clutch, but once it bites, this car throws you into the back of the seat. I'm running Continental Extreme Contact DW tires. These are the best tires I've ever run. They really hook up and are quiet and very predictable.
I did have a little scare just before going to the dyno. I went to check the SCer oil level and the dip stick came off the cap and fell into the SCer! Luckily it came out with a magnet. But it appears the plastic of the oil cap that retains the dipstick had fallen apart and fell into the Scer and mucked things up a bit. It didn't do any harm, but the oil was black! We flushed it out a few times and called it good. So far so good. Need to get a new dipstick. Also, I think the intercooler pump isn't working again... need to look at all that stuff and make sure it's working.
Finally, When leaving Green Bay, we filled up with gas and they only had 91 octane. It was amazing how much difference there is between 91 and 93! The car knocked BIG TIME! I had to stay out of the boost for the most part. I think I need to play around and come up with a conservative tune for whne I get low-grade gas in the future so I don't hurt the engine. I didn't think there would be that big of a difference, but clearly there is because when I filled up again in Michigan, I got 93 and the car felt like a rocketship again!
Regarding using 93, I found that when I was doing preliminary testing with my SC my car was very sensitive to octane. When I filled it with Ultra 94 the pinging went away. Since then I have made other tuning/setup changes and I am back to using 91, but a few points in octane go a long way if you are in a spot and need to get rid of the knocks.
#2390
Supercharged
#2391
If it were to be done "ideally" on a TS i would have 8 individual ports on the manifold prior to the intake ports of each cylinder. This would allow the water/meth jo do its job better and most importantly would be distributed equally to all cylinders.
It works as George has seen, but on our TS setup there are issues that need to be addressed.
#2392
Yes, George's is a Vortech blower. I can see there could be a plumbing issue with methanol/water injection on a twinscrew or Roots. The system George uses has 2 nozzles. One is in the air intake prior to the blower and the other is in the boot after the MAF. The system has a boost-sensitive controller for the pump and a 5 gallon tank for the 50/50 mix, mounted where the rear passenger side seat used to be. VERY effective at raising octane rating.
#2393
Caught up with you all now...
I just finished reading the whole of this thread (4 sittings) and I feel as if I have been on the journey with you as well as learning a whole load of really important stuff that I now won't need to pester you all about!
It is a thread spanning seven years and it must have made some kind of internet record as it has stayed on-topic, has not been hijacked by trolls (you guys deal with them well - couple of rebuffs then ignore!) and is still going strong.
I must admit I skimmed thro' the posts that were about tweaking the fuel pressure since I know that is not the best route to take now that the Sharktuner is available. I have made some notes which I will happily mail to anybody and I have also downloaded most of the pictures too.
I had a small 'moment' last night - I was really enthusiastic about this whole thing then I ran into the Blau posts and he really pi$$ed on my bonfire with his scorn for the plenum manifold. But then I slept on it and, actually, he offered some clues as to how to overcome some of the shortcomings of it (without spending weeks doing a CAD design which will cost a mint to machine) so I will try some improvements on my setup, and after all the plenum manifold is enabling all you guys to have some fat torque curves so it is a good thing.
I am going to sketch up my design and come up with a development process to take me from where I am now (stock '89 S4 Euro) to where I want to be (burning up the road like Tony does) and I'll keep you all informed of progress as it is (slowly) made.
Step 1 is almost complete - any news on shipping costs Hans?
Step 2 is a visit to Cambridge in the near future.
Can't wait!
I will be standing on the shoulders of giants.
Can't wait!
#2394
If you are going to try and redesign a twin screw manifold, you really should look at the engine of a C32 AMG or E55 AMG. They have the same intake paths as a 928 and have individual intake runners. Basically if you could just fabricate the intake "boxes" that attach to the heads and the box attaching to the supercharger from below that contains the intercooler, you would be almost all of the way there.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
#2395
Hans, AO
This winter I will be installing an intercooler (thanks Hans) and have been considering using separate expansion tank rather than the windshield wiper one. Please keep me in mind if you develop one.
Also, AO, those are incredible dyno charts. I don't think I have ever seen a torque curve that flat.
#2396
Hi Guys,
I have identifed that I have an intake leak, so I will be pulling the manifold etc. The intake gaskets that I have are made from the vinyl like material. While I do have some of that on hand just curious if someone has found something better. I also am curious if anyone has a used manifold laying around. Mine is the original from Andy and while it has served me well since 2005. I know that there have been some improvements there as well.
Thanks all,
Ken
Thanks all,
Ken
#2398
Ken, you need to use 1" spacers inside the manifold at the bolt holes. This keeps the manifold from deforming or warping when you tighten the nuts or bolts down. With the 1" spacers you can torque the nuts or bolts to the stock torque setting. As Ralph sayes, use stock intake gaskets with 1/8" washers to mimic the stock intake standoffs.
#2399
Guys,
Thanks for the gasket information. I posted about the spacers way back here. LOL
https://rennlist.com/forums/5446996-post1756.html
#2400
I did my tear down this afternoon and discovered that the manifold is cracked around the floor of the manifold where the individual pieces were welded together. I believe that I could repair it........but.
Does anyone have a manifold, I know there have been some substantial improvements in the design.
Any leads appreciated. I am down to about 6 weeks before my first weekend of the season instructing with PCA.
Ken
Ken
