The Twin Screw Thread
#1816
Under the Lift
Darien:
I can see evidence of Tony's handiwork all over your install. The fresh cam covers finishes it off nicely!
#1817
Under the Lift
I've looked over the various options. I'm still a little reluctant to move the jump post and coil and cut that hole, but I do have the piping and boots to do it.
#1819
Under the Lift
Also, I plan on stock torque (11 ftlbs). That's another reason the green "linoleum" probably failed to seal. I really don't want to put any more torque on these small studs.
#1820
Under the Lift
OK, all better. Jim Morton helped me cut some spacers on his lathe. I used 1/2" OD steel pipe. Fit perfectly. Ralph's 1/8" thickness spec was just right. The stock intake gasket is a little over 0.18 inch, so 0.12 inch provided 1/3rd gasket compression. I torqued the intake to the stock 11 ft-lbs but went around several times before it stayed at 11. Car idles properly now. Will finish up the heat exchanger (motorcycle radiator) install and do some street tuning tomorrow.
#1821
Bill
That's good news.
I should be getting my new crank pulley next week. It will be 6" dia. and my s/c pulley is three inches. This should give me about 6 psi boost at our altitude which I think will be a LOT more fun than the 2 psi I am getting now. Other than that I am really pleased with the way my car is running. Virtually no change in driveability except it is a bit faster.
This winter I am going to start working on a cold air intake so please keep me posted on your progress. I will do the same.
Hi, my name is Ralph and I am an S/Cic.
That's good news.
#1822
Bill,
I cut a 4" round hole in my inner fender without relocating the coil, I can't remember if I moved the jump post. I will send you some pics when I get home, I need to modify my intake tube anyways.
Later,
Woody
Later,
Woody
#1823
Bill, I too wasn't crazy about the idea, but after some thought, we chose to go with the 4" oblong hole and didn't have to relocate the coil![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
#1824
Bill,
I cut a 4" round hole in front of the ground post and above the coil. I had to take out the fender screw, but will put it back once I cut it a little shorter. The pipe is a 4" aluminum albow with a dent over the distributer cap so the plug wire doesn't rub. I built a shield in front of the filter so rain coming in around the headlight doesn't get it wet.
Hope this helps.
Woody
Hope this helps.
Woody
#1825
Under the Lift
Woody: That is sweet. I started to mount my IC system heat exchanger (motorcycle radiator) there, but I could move that to the other side.
Could you show a little more of your SC belt and tensioner? It seems the belt is spread apart a lot more than mine. Was it not yet tensioned? Mine is almost touching.
#1826
Bill,
The SC belt was not designed to be that way. When I went to the 11psi pulley the belt I ordered was a tad small. I had to run it outside the tensioner instead of inside. This is just temporary until I get a longer belt, but it hasn't slipped on me yet.
Good luck.
Woody
Good luck.
Woody
#1828
Tony / Darien
What is that material that you are using for the front intercooler plumbing?
What material are you using for the the crank case venting?
#1829
