The Twin Screw Thread
#1576
Brian: John Speake provided the link to John Kuhn's thread on the intake in the post prior to mine. I can't tell if those very nice plastic tubes were fabricated or adapted from a off-the-shelf part. They are the missing link. It looks like John strived to maintain the same cross sectional area with very wide ovals. If your aerospace engineer son is right, and I will guess he is, then a smaller piece that would fit through the existing oval in the fan shroud would be just as effective. I can tell you the Vortech's are affected a lot by upstream intake cross-section, but, of course, they aren't positive displacement.
#1577
Brian, I was going to use that design and met John at SITM to check it out. The problem was that I only needed the right side and with that small filter, you need both sides tied in to get the right amount of air. It did look sweet, but just didn't work for me.
Bill, John fabricates those snouts from scratch, he did a hell of a job in my opinion
Anyone have any contact info for him... other than the possible email link shown here in his profile?
#1578
The new 8 rib pulley is here. The diameter is 2.5 inches versus the 2.75 inch 6 rib pulley.
I was looking to gain just one more pound of boost. I made a quick pulley removal tool, (screws replaced with bolts after a trip to Ace hardware) and made a quick swap.
My math was correct and I am now at a solid 8 psi. I don't have any track time scheduled, so I am just doing some street driving with the low octane loop plugged together for a little extra safety.
You can certainly feel the difference and the sound from the 424 twinscew is up one more notch on the urgency scale.
I wish that I had a temp sensor to get my post intercooler intake temp....but I don't. One thing to do if I ever have to pull the manifold.
Does anyone have any water temperature numbers after the heat exchanger?
I am using my pyrometer and after the system is good and heat soaked I am getting a 104 - 106 degree temp returning to the intercooler. I'm just curious what other people are seeing and if I should optimize my heat exchanger more. I'm currently using a radiator from a 650 Yamaha with fan along with a 24 GPM Deandenbear water pump.
Thanks,
Ken
Thanks,
Ken
#1580
Sweet!! Where did you get the 8-rib? I've been looking for a 2.25 but KB doesn't go that small. I couldn't believe the prices that are out there!
I too would like to see some numbers before and after IC.
Thanks,
Ken
Thanks,
Ken
#1582
Where did you mount the Yamaha radiator! I have fanned EX500 radiator I'm planning to squeeze into the wheel well.
I'm attaching a pic....its in front of the radiator. If I can get some real world heat exchanger numbers that show this isn't dropping the temp enough I was thinking about buying a pair of small motorcycle radiators and like you put them in the fenderwells. There are some motorcycles out there that actually run paired radiators so the size is the same and the capacity is upwards of 1000-1200 cc engine displacement. But it would be a lot of work for nothing if I'm already in an optimized range. I have the fan for the heat exchanger tied into my radiator fan and they both accuate at 175 degrees.
You can also see my 24 gpm Deadenbear pump mounted to the front rebar in the first photo.
#1583
Have you ever experienced a "draw" problem with your pump mounted so far from the reservoir? I mounted the pump Andy supplied up in the forward space in front of the fender well, and have has occasionally had circulation failure. Apparently that pump doesn't suck well enough to pull water up over the fender and into itself.....
#1584
If Dairen reads this post (or DR or Andrew), I'd like for him (them) to get some temperature numbers going into and out of the heat exchanger. With Andrew running 10 pounds of boost....he should really be heating up the charge.
That might give me a better idea of the safety margin or lack there of.
Thanks,
Ken
#1585
Just one more thought.... there is a difference between a self priming and non-self priming pump.
The old bilge pump I removed was self priming. The Deadenbear is not, so a little extra caution was needed to route the hoses.
Ken
Ken
#1586
Under the Lift
One thing I like about many of the MC radiators is they are fanned, so, you should be able to mount it out of the main air-stream so it doesn't dump into the already taxed main radiator. However, that's not the way they are supposed to be mounted, and most of the fans are just for assist when stopped. Still, I'm going to give it a try. The one I got has a substantial fan. George Suennen runs his heat exchanger in the wheel well with a fan. I think I have the same hefty pump, purchased through Dave at SLC Motosports. The other thing I'm not sure of is the need for a reservoir. I may mount a small one and leave the windshield washer system alone. There should be an optimum size, and at some point, depending on how much hose you run and how large the radiator(s) is/are, you shouldn't need on, but I don't know the physics of calculating that.
#1587
Interesting thought...I hadn't even thought about not having a substantial reservoir. I even went so far as to draw my return from as low in the washer tank as I could get the fitting, just because I wanted to take advantage of the cooler water at the extreme bottom of the tank.....but again, that's just my shade tree approach. I have right at 3.5 gallons of capacity total....at least with this I won't be hitting any temperature spikes. Something that might happen with an undersized or limited capacity set up.
Ken
#1588
are you looking for the change in air charge temp through the intercooler or the change in the water temp flowing through it? The "air" side in my car has been wired with thermocouples since day 1. I thought about adding T-couples to the "water" side but never got around to it...pre/post intercooler and pre/post heat exchanger.
The little waterpump i use has worked fine so far. It sits at the lowest point in the system so it always has head pressure behind it.
#1589
Under the Lift
Bill:
Ken
Ken
#1590
Thanks for any info you can provide.
Ken
