Collapsed motor mount??
Anyway, what does that thing have to do with motor mounts?
Regardless of geometry or popular film, yes. A motor that doesn't move is either equipped with solid or "semi-solid" motor mounts, or the stock liquid filled mounts have failed. It's pretty common. The factory mounts are only good for a few years.
PS: I recently replaced my factory mounts with what I call "semi-solid", meaning they have solid rubber isolators between upper and lower metal parts. I mention the distinction because there's been an ongoing debate over terminology as it applies to motor mounts. It's my belief there are three types of mount:
- Solid. This is a solid metal mount. It provides no isolation between the engine and the chassis.
- Semi-Solid. Upper and lower metal parts with a hard rubber isolator sandwiched between.
- Liquid. A thick walled rubber capsule filled with gel. The stock Porsche engine mounts are liquid.
I noticed no difference going from failed liquid mounts to semi-solid. I've never really tried liquid mounts since the stock mounts in my car were long dead when I bought it.
Here Paul!
https://members.rennlist.com/pirtle/svc_mm.html
https://rennlist.com/forums/928-foru...-pictures.html
Volvo motor mounts (models 740, 940, 960 and 980) are commonly used, Volvo part no. 62 438 657
Åke
Åke
well the joke is certainly on me! had a neighbor come by the other day, who prides himself on being "all knowing" especially
with cars. he blips the throttle hard, and proclaims: "you're motor mounts are perfect. you could put a glass of champagne on
that motor, and not spill a drop. you don't need motor mounts." lol
can someone post some photos of the relationship between the manifold and crossbar, and/or the oil filler and crossbar?
I can put 2 fat fingers between the crossbar and oil filler.
I am guessing that the intake should stand proud of the crossbar? by about how much?? any photos?? thanks
Tons of them in the archives-
https://rennlist.com/forums/928-foru...sbar-test.html
https://rennlist.com/forums/928-foru...t-options.html
Here's Dr. Bob's '89 with factory mounts, 1 year post-install:
And my GTS, factory mounts, nearly exactly 1 year post-install:
You can also tell by looking underneath.
MMs in good shape will hold the bottom of the oil pan level with the bottom of the crossmember.
Squished ones will allow the bottom of the pan to be below the crossmember.
If you see the bottom of the oil pan below the rest of the underneath stuff, then the MMs are shot.
To take my "look underneath" comment a step further, post 7 of this thread:
https://rennlist.com/forums/928-foru...l#post15177406
shows what the oil pan/crossmember heights should look like.
Chronic Tool Dropper
The definitive test is whether you can get fingers between the upper and lower safety hooks that sanwich the mount. No fingers is good, one finger is fair, two or more means the mount has collapsed.
