Brumos 928
#61
Rising from the dead...Put in a regular parking spot, in the driveway, under its own power.
Porsche Lee (07-07-2019)
#64
Which are you bringing to Frenzy, Droo?
#68
9-28-18: its first real road test (about a mile) in many years. - With this drive the last of the major "known unknowns" have been eliminated; Transmission works and is quiet but has typical synchro wear (remember that the clutch was in a shambles when found, so I expected transmission issues) Engine runs well, has fresh valve drive components, water pump, etc. cracked fuel tank replaced, fuel lines done, clutch and clutch hydraulics refreshed, brake master, hoses, pads, correct exhaust back in place, instruments and most electrics sorted.
As part of the triage, every bad part of the interior has been removed : every scrap of carpet (both sets) , dash, pod and console, so we're driving around with the instrument panel bolted to its mounts without a pod for the moment. There's a lot of wires hanging all over the place but this is a great way to sort through electrics and heating HVAC system with everything exposed. ...and It does smell a lot better in there.
Next up: finish electrics, door services (windows, locks, mirrors, etc) start rebuilding interior. Chase the hundreds of neglected maintenance items remaining.
There are known knowns; there are things we know we know. We also know there are known unknowns; that is to say we know there are some things we do not know. But there are also unknown unknowns — the ones we don't know we don't know. -Donald Rumsfeld.
#69
Why are these different?
#70
posts 94, 95, and as Alex points out on post 97...there is a fix: https://rennlist.com/forums/928-foru...a-79-ob-5.html
#71
Interesting that they call the "Pearl": Metallic paint to Sample, 'Grand Prix White'/99
Sounds like it is two stage GP White with a metallic clear coat... Try matching that!
#72
Easier than you might think, they started with a GP white car, (mine is that underneath the carpets) and then paint to sample, mine is no doubt L947 perlmuttweiss mica, it was an 911 color.
https://rennlist.com/forums/911-foru...-and-name.html
#73
#74
Oh, that could very well be it, I didn't think about the primer being white, just figured just figured they took a white car just before the final coat and shot the pearl coat on it. The white on the floor boards is not very shiny. My paint code is L999 and interior code is 98 (maybe because it is just full leather and yours has the script and stripes)?
