Not a faster car, but a better car
Old 11-29-2013, 12:50 PM
RoyaleWithCheese
RoyaleWithCheese's Avatar
Originally Posted by Voith
I was thinking about how to solve this. Do you have any pictures of your bearing mod?
Here is the thread on the shifter mod:
https://rennlist.com/forums/924-931-...t-linkage.html
It's definitely one of the best things I have done to my car to date. Combined with the Only944 short shift kit it makes the car a blast to drive.
Old 11-29-2013, 01:08 PM
admiralkhole
admiralkhole's Avatar
Originally Posted by sausagehacker
You're damn right that was a great mod! They were $1.50 for 5 or something...
I have a really great gas pedal that's great for heel-toe, I believe the brand is Tilton.
I talked to Joel and the pedal was custom made...You need to post pics of it, the 944 world needs to know of it....It's the best gas pedal I've ever had the privilege of mashing. Makes heel toe driving very easy and convenient. It's a must. You can barely roll your heel while braking and blip! Your rev is there. I need to make a repro.
Old 11-29-2013, 01:38 PM
VirginiaF1
VirginiaF1's Avatar
Autothority chip for much "better" low-rev torque characterstics.
Sad they apparently are out of business but other chip tuners' products surely make these cars "better" drivers..
Can't imagine what a MAF conversion would do on top of it for driveability.
Old 11-29-2013, 03:11 PM
V2Rocket
Rainman
V2Rocket's Avatar
I just got around to installing my na-tune yesterday.
World of difference. Truly impressive is all I can say. Runs smoother, changes gear faster, pulls harder at any throttle position.
Get one. I plan to dyno again next week to quantify the maf improvement.
Old 11-29-2013, 03:21 PM
Dino V
Dino V's Avatar
Wheels and tires upgrade, brake upgrades (rotors/pads/lines), and exhaust.
Old 11-29-2013, 03:54 PM
Dougs951S
Dougs951S's Avatar
Agreed, the pedal alone makes michael's car the most fun N/A I've ever driven by a long shot. Cale, if you ever get around to making repros, count me in to buy one.
Old 11-29-2013, 06:51 PM
ZR8ED
ZR8ED's Avatar
+1 I've had the maf kit in the car for about 3 weeks now, and the difference is simply incredible throughout the entire rpm range.
Add a throttle cam, a nice exhaust, and lower the suspension 1 inch makes the car simply beautiful to drive.
Old 11-29-2013, 08:16 PM
LP944
LP944's Avatar
Since I already have the short shift kit in the rear of the car, would it be too much to add the front one as well?
Old 11-29-2013, 09:25 PM
mytrplseven
mytrplseven's Avatar
It would be overkill since the one mfr'd by only944.com reduced throw by 30% in all axis. I've heard other technical arguments against it as well but can't recall the specifics. For me, I just love mine.
I also added 17" Cayman wheels w/BFG G-force radials of proper diameter. Great tires for Florida downpours where the pavement disappears. Thinking about stiffer and shorter springs for better handling and ride. Also saving for the NA-Tune.
Old 11-29-2013, 10:52 PM
Rudybuck
Rudybuck's Avatar
I installed both items from only944.com and it works great. I used the lower stock position on the rear shifter. Very happy with how positive the shifter is now.
Old 11-29-2013, 11:36 PM
LP944
LP944's Avatar
I believe I have the Schnell short shift kit, I hope noone has run into issues with this particular one?
Im looking into the shifter because the play is very bad now.
Old 11-30-2013, 12:13 AM
goatfarmerdave
goatfarmerdave's Avatar
+1 Rogues na tune.Simply the best bolt on upgrade ever made.It transformed my car.Couldn't believe the orqu difference.Go to hi website.He has been around for a while and is a guru in the turb world.
PS-Do not know Josh at all personally.Just telling you guys the truth.Cheers.
Old 11-30-2013, 12:14 AM
goatfarmerdave
Apologies for spelling.On bad keyboard at work right now.
torque
his
turbo
Old 11-30-2013, 02:14 AM
LP944
LP944's Avatar
Saving up for the NA-Tune! 10 percent claims usually?
Old 11-30-2013, 05:03 AM
Voith
Voith's Avatar
wow, that. only944 short shifter really looks good.
Thanks. I will do something similar to mine, factory approach to this is just idiotic.
Quick Reply: Not a faster car, but a better car
