alllllmost done.... build pics
Old 02-05-2010, 09:07 PM
  #136
krystar
krystar's Avatar
so much bling! hehe
Old 02-07-2010, 02:10 AM
  #137
Cass944
Cass944's Avatar
fuel lines are done
that should be everything... i just need some battery cables
Old 02-07-2010, 02:11 AM
  #138
Cass944
Cass944's Avatar
i REALLY want to find a way to get rid of that gross air flow meter... the thing is huge and ruins the whole engine...
Old 02-07-2010, 02:12 AM
  #139
Cass944
Cass944's Avatar
oh and i need a coil wire... one that will go from the distributor all the way to up where the battery used to sit...
Old 02-07-2010, 02:25 AM
  #140
krystar
krystar's Avatar
paint it black and surround it with red things. hope it just melts into the background.
maybe a garnet red water return hose, garnet red jboot. garnet red airbox top cover
Old 02-07-2010, 09:23 AM
  #141
FabilichuS
FabilichuS's Avatar
Why don't you do something like this, realy nice way to dressup the lady alittle more
Old 02-07-2010, 10:17 AM
  #142
ernie9468
ernie9468's Avatar
Wink
just adding my two bites !!!!!
Old 02-07-2010, 11:44 AM
  #143
Mike C.
Mike C.'s Avatar
Fabilichus, do you know exactly what was done with the crankcase ventilation in those photos? Where does the filter next to the fuel rail go? Is the auxiliary air valve still connected?
Old 02-07-2010, 02:54 PM
  #144
krystar
krystar's Avatar
yea there's two hookups for extra vacuum...one is crank vent out of the top of the AOS that goes to the JBoot. other comes out of the bottom or the front of the intake manifold and that's where the IACV/ISV hook to
i think fabilichus' fuel rail one is the AOS hookup and the extra little breather near the main filter is prob what IACV/ISV pulls from. technically if that were true, the extra idle air isn't metered...not that it's a big deal hehe
Old 02-07-2010, 03:01 PM
  #145
krystar
krystar's Avatar
oh....air filter showoff hehe
Old 02-07-2010, 03:10 PM
  #146
krazykarl
krazykarl's Avatar
So Yuliang, how long do you think engine #3 will last? =)
Old 02-07-2010, 03:20 PM
  #147
Olli Snellman
Olli Snellman's Avatar
Try to keep is clean as possible.Do not add multiple colors, like red, yellow or any other bright color. This picture of yours is so clean, like hot rod style where most hoses, wires etc. are hiden and cannot be seen at all.Keep up buildin it that way.
Old 02-07-2010, 03:28 PM
  #148
krystar
krystar's Avatar
engine #3? this is only my second hehe. and no low oil pressure like what killed the last one. i knew that one was a goner.
Old 02-07-2010, 03:30 PM
  #149
krazykarl
krazykarl's Avatar
ah, though you were on #3. What was the cause of the low oil pressure? You have a cracked pickup tube at one point didn't you?
Old 02-07-2010, 04:41 PM
  #150
krystar
krystar's Avatar
yea hehe that was orig engine. i just ran the **** outta it. i replaced the rod bearings but that wasn't it. it was prob something else much more complicated. i just keep on running it until it died. lasted all summer of track events hehe. i swapped over my reinforced pickup to this engine
Quick Reply: alllllmost done.... build pics
