VR 944 PROJECT
#76
From: Nashville///'84 944NA, Virtual Luftwaffe pilot, Fighter Ace online
Yeah, but I'm pretty sure he'd have to knock his brother over the head or something---I believe those motors are still in running cars, lol...
#77
Question for you race guys: Is there such a thing as quick-disconnect fittings for coolant, fuel, etc?
#78
Yup. Should be able to get Aeroquip's version at any race shop, or the imported Wiggins or Staubli versions.
I've worked on a dozen different types of single-seat formula cars, and pretty much everything below the Indy Lights level has used old-school hose clamps. Chiefly for reasons of cost...
#79
Audi's 3.2 is all-aluminum, which is nice from a chassis dynamics standpoint. Uses a dual-mass flywheel to quell vibrations out of the 90-degree six, tho. Problematic? I dunno.
Also, possibly less practical for a racing program (my plan) from a cost and spares standpoint, though I haven't asked around enough on that yet. Definitely, though, zero aftermarket support. Don't know why.
Ironic bit is that the Audi six has a notorious issue with its timing chain tensioner. Go figure.
#80
VR is the way. the stairway to heaven if you will 12Vs are bullet proof and sound sweet! Please dont forget while talking about and throwing out Hp numbers for VRs and Porsche's, that even though the VR is up only 20-25 HP from an n/a, it has alot less mass to haul around then it did in any Mk3-4 (major P/w ratio increase), and engine swaps typically bring out the animal inside of engines and display completely different characteristics. Now imagine an already mean motor doing this
#81
My brother has a Corrado SLC (which comes with a vr6) and a mkII gti (into which he put a vr6). Both run and I am not allowed to touch. Though the 'rado has rod knock. I was thinking of buying a new engine for it, and taking the one with rod knock, so I could rebuild it with a new crank and full rebuild.
Whatever the displacement, it must be 12v. I want torque, as much of it as possible, and as early as possible!
#82
ot,
arash, what color is your 944? i was on the way to SLO the other day (coming NB on the 1) and got passed by a black one, and then when on cal poly's campus saw a white one. either of those you?
i was in an rv btw lol
#83
Now have a bare VR block, head, and valve cover in hand. As soon as I get time, I'll begin fitting in the engine (Injun? lol) compartment. I'll also take comparison pics of the 944 block and the VR6 block. For now, here's a pic of the old 944 head sitting on top of the VR block...
#85
A pic of the VR6 aluminum head, and the 944 and VR6 block side by side...neither head or block has been cleaned up yet. If the bores were equal size, the VR6 would be equal in length to about 4 1/2 cylinders on an inline four. As is, it is considerably shorter than the 2.5...
#88
I don't have any way to weigh the blocks, but...according to an article in Consumer Guide, the 944N/A engine weighs approx 340 lbs dry...according to one of the members at VW Vortex who shipped one recently, a VR6 longblock weighs 390 lbs, which I think is probably a fairly accurate comparison...if you remember that the 944 block, although aluminum, is somewhat larger, has a longer crank, and balance shaft weight to boot. If you were to talk about a 951 engine and all its associated hardware, the difference becomes negligible...I may opt for heavier springs at some point, though, since I plan on adding a turbo.
#89
Interesting project, i wonder why my australian friend wrote he does not like VR6 engine's sound. My eldest son owns a VR6 Golf III and it's a real nice car. I just love the sound of his car. He has a special made exhaust with race cat, also intake is a bit modified, engine is quite stock, we just changed chip. Your mod is far more interesting than putting old tech V8 engine in.Keep up good work, like to see lots of pictures of your project
I'm liking this project. I still like the i5 in this project a LOT. For you guys that haven't seen it, check it out.
https://rennlist.com/forums/944-turb...4-project.html
Keep up the great work VonoV.
EDIT: Just saw the pics of the block. What an amazingly narrow thing it is for a V motor. It hardly constitutes the V designation. Nice and compact.
I'm wondering if it's worth doing it forced induction from the start and save a bit of money down the track?
