Exciting supercharger info for all 944 owners. COME IN HERE!
Old 02-01-2005, 07:27 PM
  #46
DVC
DVC's Avatar
SoK also sells the kit with I/C for about $900 more than the non I/C kit.
Old 02-01-2005, 07:36 PM
  #47
AZ968Cab
Cab'n It
AZ968Cab's Avatar
I just dug around on google and found a post on roadfly about the SOK folks.
**Disclaimer** I just ripped someone on another post for dissing a shop (the shop I use in Phx) in a chat. Bad, incorrect and incomplete data and it's easy to do that where there's no accountability (chat room...). Therefore I'm not qualifying the following, just sharing it.
http://forums1.roadfly.org/porsche/f...4108141-3.html
Old 02-01-2005, 07:39 PM
  #48
DVC
DVC's Avatar
Now do search on Pelican and notice that it's all positive.
Old 02-01-2005, 07:52 PM
  #49
AZ968Cab
Cab'n It
AZ968Cab's Avatar
I will. That was just the first post I found. As I said, I don't believe in blasting honest folks without first hand experience, I just wanted to share.
Old 02-01-2005, 08:25 PM
  #50
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,201 Likes on 1,242 Posts
Originally Posted by DVC
I finally decided against this as the centrif. is a compromise. The 944 *needs* a positive displacement blower.
The only thing a 944 needs is more power. Forced air of any kind (done correctly) will do this. Fish around the 928 forum, this discussion has been beaten to death. Bottom line is this - any blower on a 928 makes more power at all RPM's vs a stock motor.
On a 944 you will get the same result. Some people say "Power below 2,500 will not be as good on a centrifugal supercharger". I own a 944S, the only time my motor is below 2,500 is at a stop sign or cruising down the highway - so it's a non issue.
Old 02-01-2005, 08:38 PM
  #51
DVC
DVC's Avatar
I'll post a dyno sheet of a 944 with a centrifigul blower (with 7-8 psi).
Old 02-01-2005, 08:41 PM
  #52
hacker-pschorr
Cool, lets see it! Is it IC? And could you also post the A/F it was running at the time per RPM?
Old 02-02-2005, 09:38 AM
  #53
AZ968Cab
Cab'n It
AZ968Cab's Avatar
Erik, that's way funny about the 2500 RPM...
Old 02-02-2005, 09:45 AM
  #54
hacker-pschorr
Well, it's true. I have not been able to drive my 944 since 2001 (rod bearing, dedicated all funds and time to the 928 after that). IIRC, even on the highway doing 75mph it's close to, if not over 2,500 rpm.
I guess I don't see any reason to spend all the money on a SC then lug around town with the engine at idle speed just to prove the low end boost is needed. Rev the f*cker! (maybe that's why my bearing whent -kaping).
Old 02-02-2005, 10:36 AM
  #55
Carl Fausett
Developer
Carl Fausett's Avatar
...not to mention that a load at 3,000 RPM is easier on rod bearings than a load put on the motor at 1,000 RPM. Lugging the engine is harmful, as is full boost at idle speeds. (Ten bucks says THAT statement will start a war...)
Old 02-02-2005, 10:38 AM
  #56
Carl Fausett
Developer
PS - my target of < 4k for the SC kit is non-intercooled. 6 psi. Intercooling it costs more. Just like in the 928 kits we make.
Old 02-02-2005, 11:33 AM
  #57
ckathens
ckathens's Avatar
$4k sounds great. I'd get that for my 944 future track car. (currently garage queen). And if you decide to do a 968 kit for about the same amount, i might consider that as well. Currently 968 Turbo kits are ~$20k+ at this point.
Old 02-02-2005, 01:04 PM
  #58
hacker-pschorr
If you have not seen how a factory 951 IC is setup - take that into consideration when designing your kit.
If a factory 951 IC can be added to your kit with just some plumbing changing - that will be a huge feature vs trying to stuff one of the air / water setup the 928's are using.
Someone post a 951 front end with the nose panel removed.
Old 02-02-2005, 01:06 PM
  #59
Lumbergs Lackey....MmmmKay
Lumbergs Lackey....MmmmKay's Avatar
Carl, will the kit work with a 951 intercooler and would you ever use one or will it be a custom intercooler placed in the nose of the S2? You can find 951 intercoolers pretty cheap on Ebay. Keep up the good work. The nose panel on the 951/S2 had a lot of space up there.
Old 02-02-2005, 02:12 PM
  #60
DVC
DVC's Avatar
I'm sorry I haven't posted yet, will get to it tonight.
The reality is is that the kit won't sell for $4k. It probably wouldn't even sell for $2500. SoK makes one now for less than $4k (that includes everything including the chip) and he gets ZERO interest. I mean guys don't even call him or email him! 944 owners are on a completely different level of cheapness than 928 guys. They'll talk about it endlessly on the net but when it comes time to part with the green, forget about it.
That doesn't mean you shouldn't do it though
Quick Reply: Exciting supercharger info for all 944 owners. COME IN HERE!
