Smog on '76 Euro Carrera
Wow, a lot of plumbing there, not what I want done. OBTW, this is the one with the 2.7 - 210HP. So one way or another its coming this way.
If your car isn't exempt by its importation docs :-) (wishful thinking) ,you possibly will be able to retrofit
a somewhat later catalyst system like off of a '77 to '83 ,heat exchangers,crossover,cat and muffler
could possibly lean out exhaust sufficient to pass ,otherwise hope like hell 1976 has been exempted
altogether , it's possible.. Bert
oh and that above pic is of a full race 1976 934 turbo with air to water intercoolers that most certainly wont
pass!
pass!
Looking at the picture does it look like there's a piece missing, like the large plastic piece just above the coil. I am thinking plumbing for the aircleaner. I am just getting familar with the Porsche engines so it just seems from looking at others there was a large black plastic piece that attached to that elbow above the coil. Educate me, please
The California CARB will require you to take the car to a registered importer. They will not allow you to do the work yourself or have a local garage do the work. There is a two part requirement by California. The first being it will have to upgraded to pass DOT regulations which is strengthening and lighting buckets to meet US requirements. The second is passing current smog requirements which will be quite expensive. I believe there are two registered importers in SoCal and the CARB (California Air Resources Board) will provide their contact information. I went through this ten years ago and it was not cheap then so I expect it will be worse now so be prepared. Curt
