OEM Navigation Retrofit DIY
#331
I went though the latest aio method. Install went exactly as described by the video on the mib site. When I plug in my phone (pixel 7) there's no android auto icon anywhere.
#332
I installed this software to give it a try and see how much faster it was than the website download. Not exactly sure how to best use it. Do I paste the URL of the MIB directory and then select the map file?
Free Download Manager
https://www.freedownloadmanager.org/
#334
Install Download manager as per their website's instructions, your set up as to file download location is up to you, once done and you click on a download it will intercede and manage the download after confirming your selection.
#335
#336
Now isn't that interesting! I have a Pixel 7 Pro and have had no issues. I would be curious if you now tried your phone now without the MA1 it would work?
#337
Nope doesn't work still. Very strange issue.
#338
I figured it out. once you install the software (via link above) go to Preferences and then Browser Integration. Pick Edge or Chrome extension, install and then try again. I use Chrome and once I installed extension, then clicked on download in MIB site, FDM window popped up and was ready to go.
Z06jerry (01-04-2023)
718socal (01-04-2023)
6IXSPD (02-02-2023)
#343
People with NA '22 Spyder, did your car come with the antenna?
santiago660 (02-02-2023)
#344
@718socal
Thanks for your great work here!
As I got it right the AIO method is only for US cars right?
For a German car (EU) I have to follow the steps from post #1?
I was able to run M.I.B. AIO patch today with the help of @CaneTLOTW and others.The installation is much easier and cleaner.
You would still need to code the cluster with PIWIS and install the LVDS after this.
Please watch this video.
https://youtu.be/QPRqR47_9qo
This patch will work for any MHI2_US_P0G11 firmware directly to MHI2_US_P0G11_K5186_1
You can find the file needed (MHI2_US_POG11_K5186_1_MU1476_AIO_20220703_beta) here.
Follow this link for detailed instructions here.
#345
@xterm What is the version of your PCM?, if it is not as shown in the picture in post #1 then I don't think AIO will work for you, but you still might be able to manually update the firmware if the appropriate versions/patches are on MIB.
