Cobb Tuning Accessport for 718 (982) 4.0L NA Engines
#77
Call me a sceptic, but really doubt 60+ HP on a GTS. Happy to be proven wrong.
#78
Basic Sponsor
Not looking for a tune, but curious
Write-up indicates tune (stage 1 map) was created and tested with stock everything
What if an owner does not have stock everything (e.g., aftermarket exhaust) . . . does that mean the stage 1 map is not optimized and will require an individualized map?
Avera
Avera
If i was doing the marketing offering i would absolutely choose the comparison to the model that Porsche restricted vs. the best run of the one that didn't for obvious reasons! I would go and find the poopiest spot on the curve for the stock car and then go and find the best part of the curve for the tuned GT4 with the most jam and that's the number i would use IF i didn't believe in underquoting every single thing i sell so i can impress not disappoint...
Awesome! I got it. We have a new additional sales associate by the name of Doug that is here to assist AJ!
Santa doesn't even have to put it in his sack when he comes down the chimney, Fedex or UPS handle that! Just bring it to his workshop to put it on the Dynojet!
#79
I'm always skeptical about every single thing that's printed for the purposes of selling. I've been at this for two decades and remember a time when 7rwhp on a 987.1 was a big deal. I'm old school so if you give me 15rwhp from a tune on an NA car and almost 80rwhp on a tune for a turbo car OVER WHAT PORSCHE DOES and i'm stoked. This car woke up a lot from the tuning. I stropped paying attention though after the 20rwhp number cuz i saw all i needed to.
Cobb is +8% HP+ over Softronic and +10% HP over M-Engineering (Stg 1 93). That's a fair amount for those other tuners to be leaving on the table, so Cobb must have some magic. Great gains. Stage 2 in the mix ever?
#80
John at BGB is a tuner who is conservative and very track oriented. In my experience several cars worth his tunes will run for full 30 min sessions at Sebring in the summer and not pull power. I also like that he follows the NASA dyno protocol on all his tunes Dynojet SAE correction smoothing 5.
Peter
Peter
#81
The car is very good at handling additional increases in air flow. It can adapt nicely to revisions to the exhaust. If you start dumping filters though, while the flow will increase if you go so far as to trigger a CEL, then the map will revert to something with a fatter mixture.
When you say ‘dumping filters,’ I am under the impression you are referring to cats/resonators from headers and OAPs?
In other words, with regard to exhaust modifications, stage 1 tune is not intended for anything more than swapping out the OEM rear box? Pretty typical that most stage 2 maps tend to be developed for ‘increased flow.’
I sense COBB is focused on not offering stage 2 mapping because they want keep everything emissions compliant. More than that, given the multitudes of aftermarket header/OAP/rear box replacement options, I think this is wise because it would be nearly impossible to produce a generic map that suits all the different ‘flows’ that could be produced. In other words, after stage 1, it seems every aftermarket tune should be individualized (e.g. pro-tunes). Better for both the tuners and consumers in the long run.
Avera
#82
Basic Sponsor
We aren't likely to make an OTS Stage2 map due to emissions. But that doesn't mean we don't have other maps to look forward to!
- Andrew
![](https://rennlist.com/forums/signaturepics/sigpic141208_1.gif)
PORSCHE EXPERT GROUP - TIM | GRANT | HJ | ANDREW | JARED
COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE |CONTACT US
The following 2 users liked this post by COBB Tuning:
Benzwiz (11-24-2022),
Clark_Kent (10-27-2022)
#83
Thanks for the explanations. Can you share why the dyno charts end at around 7,500 RPM well short of redline and fuel cut?
#84
@COBB Tuning
In your testing, what did you find represented the weak link, or limiting factor?
For example, I had a 2018 Macan Turbo with a COBB stage 1 tune. As was quite commonly encountered and reported on the forums, the tune produced too much boost pressure for the stock diverter valves (weak link). Short of replacing the diverter valves, I could not get any pro-tune to overcome the issue.
By no means meant to disparage COBB or your tunes. You have a great reputation for producing great tunes. I am simply inquiring what OEM component(s) was a limiting factor in your GT4 stage 1 tune?
Avera
Avera
#85
Basic Sponsor
@COBB Tuning
Avera
Avera
Avera (10-27-2022),
#86
The biggest factor on these cars is heat. They're extremely prone to heat soak and the airflow into the side ducts isn't great, especially on a dyno. If you plan on live monitoring with an AP, I would definitely watch temps. We did some work to try and manage how the ECU responds to the heat but it's unavoidable. So cooling mods definitely help!
Avera
#87
#88
#89
Basic Sponsor
Correct. Porsche typically publishes numbers at the crank. During engine development. They'll typically tune the engine outside the car as it gives them much better control over environmental factors and allows for much faster work.
#90
Seems like you could do some math and get close.
https://cobbtuning.atlassian.net/wik...ges/2718007297
