718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
GT4 RS Allocation Thread
Old 12-08-2022, 10:13 AM
  #1696
jmartpr
jmartpr's Avatar
Received 1,481 Likes on 921 Posts
Originally Posted by Odin
Why wouldn’t you track PCCB’s? I’ve got the Manthey brake upgrade on mine just precisely to be able to track it without longevity issues, fading issues or dust issues, all with superior brake performance.
Because on this side of the pond, for track rats like several of us, once you upgrade the pads you have better performance/feel than PCCBs, even with the Manthey pads, while saving $$$$
I'll take the better braking and savings over the +/- 4-5 lbs of weight savings on each corner ands no dust.
Old 12-08-2022, 10:20 AM
  #1697
Adrift
Adrift's Avatar
Received 2,596 Likes on 1,320 Posts
I’m still confused why he can claim economy when pccb rotor replacement is astronomically expensive.
Old 12-08-2022, 11:46 AM
  #1698
jmartpr
jmartpr's Avatar
It all comes down to use.....if you don't track or only do it a handful of times per year PCCBs could last a very long time and the performance is very good out of the box while saving unsprung weight.
Of course that comes at the cost of adding them to your build, which is not that bad considering the replacement cost. That's why PCCB cars get more at resale, besides the secondary market being misinformed about brakes.
Now if you pound on them at the track it's no secret the way PCCB disc are build could result in lots of $$$$...in this regard ST are way better.
Mr. Adair (12-08-2022)
Old 12-08-2022, 11:55 AM
  #1699
FazedChicken
FazedChicken's Avatar
Why not do this:
1) Get PCCB and track it like usual
2) When they're gone, get Girodisc or similar iron replacements that fit PCCB size
It's like getting a factory big brake kit. If your first set of PCCB lasts 2-3x longer than the stock iron setup, then you're already ahead and you have a bigger braking system too once you're comparing stock iron vs PCCB sized iron.
That's my plan. Unless there's something I'm not understanding correctly and PCCB will not last 2x the stock irons on track.
Odin (12-09-2022)
Old 12-08-2022, 12:17 PM
  #1700
ExMB
ExMB's Avatar
Received 1,374 Likes on 834 Posts
Originally Posted by FazedChicken
Why not do this:
When you get to sell/trade the car you will take a $20+k hit to put it back into OEM config.
Old 12-08-2022, 12:18 PM
  #1701
jmartpr
jmartpr's Avatar
Why not do this:
Bigger? It's only 2 mm more in diameter vs the Iron setup on the 4RS.
IMO all these cars have more than enough brakes, even with 380 mm Irons on the GT4. You are limited by how much the tire will hold/have traction.
APs system is 394 mm and PFC is 380 mm (405 mm front is optional).....and I'm pretty sure those are up to the task.
Bigger more expensive is not always better....
Old 12-08-2022, 12:25 PM
  #1702
Westcoast
Westcoast's Avatar
Received 4,718 Likes on 2,746 Posts
If I was worried about the cost of replacing my PCCB rotors, I would swap in a set of ST rotors and box up the OEM set for the future. I don't get to the track a lot but have considered this move just the same.
  #1703
Adrift
Adrift's Avatar
Odin asked why wouldn’t you choose pccb for a track car, then said they were more economical. Thus the disconnect in my head. I assumed he meant more than incidental track use.
I bought my pccb planning only incidental track use (a DE a year-ish), so I hope you guys’ assessment that shouldn’t meaningfully impact rotor life is right! lol I’m literally banking on it.
Old 12-08-2022, 12:36 PM
  #1704
Westcoast
Westcoast's Avatar
Me as well, although I get out about 6-8 times a year, which started me thinking about ST rotors...
Old 12-08-2022, 01:03 PM
  #1705
IPSA
IPSA's Avatar
Why not do this:
Take ceramics off day one and use Giro or Apex J hooks. When time to sell put ceramics back on and they will be brand new. Resale will be far better this way. Swap is generally 2 hours of labor per axle.
FazedChicken (12-08-2022)
Old 12-08-2022, 01:40 PM
  #1706
ExMB
ExMB's Avatar
I don't see anything in his post discussing economics. Longevity can mean fade resistance depending on how long you are out there.
Odin (12-09-2022)
Old 12-08-2022, 01:42 PM
  #1707
sdillon
sdillon's Avatar
Am I being naive to think that resale value on a PCCB equipped car would be the same regardless of whether it had Porsche PCCB rotors (either original or OEM replacement) or Surface Transforms rotors? I assumed that if I decide to sell the RS, it won't really matter if it has the OEM PCCB or ST rotors. If I replaced the OEM PCCB rotors with iron, sure, but with ST rotors?
My plan is to spec PCCB, use the stock rotors until they wear out, then replace them with ST rotors as many times as needed while I enjoy the car (which involves a lot of track time).
My alternative was to go with iron and immediately replace them with AP racing brakes and rotors so at least the weight savings would be in the ballpark as PCCB. The cost of AP Racing brakes and rotors is a bit more than the PCCB option, so I'd call that a "wash" at time of purchase. I am thinking/hoping the ST rotors are at least comparable in running costs to AP Racing iron rotors given that the ST rotors can be resurfaced up to 4 times (I believe) before needing to be replaced. Anybody have any numbers to validate or shoot down my hope?
All that's left in my mental equation is (a) brake feel, which is subjective and we're all going to have our own preferences, (b) the AP brakes permit easy pad swaps without taking the calipers off, and (c) PCCB or ST rotors will keep those expensive blue Mg wheels cleaner. I know appearance is vain, but man I spent a lot of time keeping my Forgelines clean of dust from DS 3.12 pads on my 981 GT4.
Odin (12-09-2022)
Old 12-08-2022, 01:44 PM
  #1708
sdillon
sdillon's Avatar
Ignore my PCCB post above please. Wrong thread for that. I'm sure people will tell me to read through the existing debates on PCCB vs iron, and rightly so.
Porsche2014 (12-09-2022)
Old 12-08-2022, 01:46 PM
  #1709
Adrift
Adrift's Avatar
Hmm, true, but he did say fade right after longevity, so I guess that led me down the "benefits of long term use" intellectual path as the/an alternative; possibly erroneously.
Back to allocation talk?
Question on how these ADMs are typically structured...say you agreed to an ADM like $100k or whatever, but your car is in the queue somewhere to be built in the future (and possibly slipping). And now cars are showing up here, including dealer spec cars, with much lower ADM due to softening market. Are folks typically locked into those original ADMs? What kind of obligation is typically expected? Or is it totally variable by dealership? Are folks renegotiating all those (previously) higher ADMs?
Old 12-08-2022, 02:42 PM
  #1710
Bahnbrenner
Bahnbrenner's Avatar
Deviating back to the topic of GT4RS allocations - I've been holding out for a GT4 allocation from a small dealer in the PNW for a very long time. They've apparently gone two and a half years since being given GT4 from PCNA. Anyways, I got a text out of the blue from my SA offering me a 4RS last week. March build, June delivery, $50K ADM. It was very tempting to go for it, but I ended up turning it down.
I work in tech, theres a global recession looming, and the specialty car bubble has (with very few exceptions) well and truly popped.
DFW01TT (12-10-2022)
Quick Reply: GT4 RS Allocation Thread
