Dundon "Making the 718 GT4 Faster"
#61
Basic Sponsor
@Jamie@dundonmotorsports What are the tuning options?
ECU clone, ODB2 port flashing, dyno tuning, and e-tuning (start with base file, iterate via logs)?
For now it’s bench flashing. ECU clone we’re discussing, OBD2 is possible as well. Not sure if Cobb is working on this iteration, but they do have the 991.2 Carrera and the 718 4banger turbo so maybe just a bit of time...
Dundon Motorsports
Gig Harbor, WA
253-200-4454
jamie@dundonmotorsports.com
www.dundonmotorsports.com
Facebook.com/dundonmotorsports
Instagram @dundon_motorsports
Dundon Motorsports
Gig Harbor, WA
253-200-4454
JAhmed (11-01-2020)
#62
Correct to assume dyno tuning using bench flashing is available at your shop?
#63
Basic Sponsor
Thanks @Jamie@dundonmotorsports
Also since the 991.1 GT3RS was rated at 500 crank hp, and the 991.1 GT3RS made 430whp on our dyno, does that mean since the 718 GT4 makes 434whp on the same dyno under the same conditions that it's now 500hp at the crank? discuss... lol
The following 2 users liked this post by Jamie@dundonmotorsports:
Knutsm01 (11-01-2020),
porscheflat6 (11-02-2020)
The following 4 users liked this post by Jamie@dundonmotorsports:
The following 2 users liked this post by 911therapy:
mr gregash (11-02-2020),
The following 3 users liked this post by Jamie@dundonmotorsports:
#69
I assume that in your solution the cats are located where the OPFs are usually to be found? Is it therefore possible in EU cars to connect the sensors for cats AND OPFs at this spot to avoid CEL? I think this is the approach capristo is using to make it work plug & play in the EU.
#70
This is the question i have been pondering... starting to think we really ought to look to other performance data as well to help with other references towards standardised comparisons.
#71
It is certainly a question worth discussion, but I do think real world results speak louder. 1/4 trap speeds, 60-130 just to name a couple.
#72
Basic Sponsor
Once the development is finished, I agree that getting 1/4mile traps or 60-130 is a good indicator of the power, just have to get a lot of them as there is definitely some technique required to make them consistent.
sobiloff (11-02-2020)
#73
I think Dundon is providing the most cross referenceable data since theyre using the same Dyno with same conditions etc... 1/4 Times and 60-130 have way too many variables.
Good work Dundon!
Good work Dundon!
#74
M-engineering can handle all that so yup.
