718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
SOUL | 718 GT4/Spyder Exhaust Development
Old 10-09-2020, 01:13 PM
  #331
Larry Cable
Larry Cable's Avatar
Received 3,627 Likes on 2,355 Posts
@Soul Performance curious why you chose no heat shielding on your product vs.OEM (and Akrapovic)?
Old 10-09-2020, 01:23 PM
  #332
Soul Performance
Basic Sponsor
Soul Performance's Avatar
Received 1,902 Likes on 985 Posts
Originally Posted by Rennolazine
Thats too bad. So what im gathering is either the valves or the muffler need to go for full sound potential.... and revving like a hooligan. Lol. are you also saying that when you press the pse button theres no noticeable difference unless your driving above the point where the valves open? Ive seen videos from caragraphic and other fabricators where “pse on” not just valve controllers make a difference in rev volume and burbles. Is the car just running a richer mixture if its not a change in the exhaust path?
Valves and mufflers are all fine to have, you just have to decide how you want them controlled to either be on maximum attack all the time, or close the valves and fly under the radar only when you want to. If you are sitting at a standstill and press the PSE button, you can rev the car with valves open to 5k rpm. If you keep that button pushed and lit up and gently get the car moving you can then rev it with valves open until redline. Still with the PSE button pushed and lit up, if you start to accelerate the valves will close automatically until they reopen at 5k rpm. That's the problem with the PSE programming, the valves Do Not stay open with the button pressed like they did on the previous generation 981. This is due to more stringent sound restriction in Europe, and we got the short end of the stick.
Originally Posted by Larry Cable
@Soul Performance count me in for a pair of slash cut, double wall, satin black tips with either "Spyder" or "718" lettering!!! (in addition to my OPF pipes)
You can count me in on that project, we'll make it happen : )
Already covered that in depth a few times earlier in the thread "Like the previous generation 987.1/987.2/981 exhaust systems (not from just us but most every exhaust manufacturer) we've found heat shielding to not be necessary to include. If our over axles pipes maintained a giant heat soak at the end in the form a particulate filter right by the rear tire, then yes a heat shield may be necessary. However, those are gone and no longer a concern.
For those that simply want to go above and beyond with cost not being a factor (no such thing as too much heat prevention) we will provide an optional service of having our over axle pipes sent to Jet Hot Ceramic Coating to have the pipes coated in their entirety with their 2500degree ceramic coating, which would provide better thermal retention characteristics vs a heat shield covering any portion of the exhaust."
Best regards,
John Gaydos
SOUL PERFORMANCE PRODUCTS
Quality Exhaust Solutions, Fair Pricing, and Outstanding Service
John Gaydos- Owner, Performance Specialist
Cell - (484) 883-6197
johng@soulpp.com
Jon Wheel - Marketing Manager
jwheel@soulpp.com
Old 10-09-2020, 01:24 PM
  #333
Larry Cable
Best regards,
John Gaydos
SORRY for being lazy ***!!!
I might be interested in that coating!
Old 10-10-2020, 09:08 AM
  #334
Rennolazine
Rennolazine's Avatar
Best regards,
John Gaydos
Gotcha so with a muffler path design a valve controller is almost unavoidable if you want a more aggressive option. Good to know at least the volume can be altered at a standstill while revving with stock pse. However having the valves snap shut while rolling all the way to 5k rpm even with the PSE on is a travesty. I would be always chasing 5-8k rpm and you know where that lands you with the long gearing. At least your muffler will undeniably be louder than the OEM baffled garbage can strapped back there.
Old 10-10-2020, 08:19 PM
  #335
mjw930
mjw930's Avatar
Pull the vacuum hoses off the valves, plug the hose and poof, you have the sport exhaust 100% of the time for about $2.00. If it’s confirmed that cylinder deactivation is also shut off when you turn off AS/S then you’re good to go. One of the main reasons for closing them is to muffle the horrid sound of running on 3 cylinders.
Old 10-10-2020, 08:27 PM
  #336
Westcoast
Westcoast's Avatar
Received 4,711 Likes on 2,741 Posts
Confirmed that cylinder deactivation turns off when Auto Stop/Start button is set to on!
The only thing for me and some others and the reason for the valve controller is I don't want Sport exhaust on between idle and 4K Rpm all of the time, there are times to be stealthy too.
Old 10-10-2020, 10:20 PM
  #337
mjw930
mjw930's Avatar
Agreed but I suspect the stock exhaust with the OPF delete pipe and valve open all the time may be quieter than an aftermarket header, pipe and muffler delete with valves would be closed. It’s certainly worth testing and finding out before you drop $5K+ on an exhaust.
Old 10-11-2020, 11:18 AM
  #338
Westcoast
Westcoast's Avatar
At this point I am only installing the OPF delete pipe and valve controller, from the video posts with just the OPF delete and valves open this will be enough for me.
And remember above 4K RPM you shouldn't force the valves closed with any system...
Old 10-11-2020, 05:19 PM
  #339
tdlondon
tdlondon's Avatar
Originally Posted by chalkspyder
Let me put it this way. The stock PSE programming completely ruins the experience. It's not even worth a conversation because all it does is close the values in a rev band that you spend most of your time in while driving normally around town...meaning, you only hear the exhaust note of the valves being open as you stop at a light in idle or if you get the RPMs above the 4s while moving. The "while moving" part is important because this behavior only shows up if you are moving - said differently, if you are stationary and you rev the engine it does not close the valves. You have to experience it to understand how completely annoying it is and after a while you find yourself upset everything you drive the car. With the controller you can force the valves to be open all the time (bonus is if you drive with it open all the time...it stays open even after your shut off and restart the car...v resetting every time you turn off the car). You can always turn off the valve controller with a button click which gets you back to factory PSE operation. In my opinion, I don't really see this as an option....valve controllers are a must regardless of whether you are changing the exhaust system or not. Its a big improvement on the factory experience.
Totally agree and I go beyond: The OEM PSE actually only helps between idle and 1800 RPM and maybe between 4-5k. After 5k even with the PSE off ("closed") the valves open and it screams as it should!
Another perk of the valve controllers is that you can program them to work with the home link buttons. So I opens my garage, II opens the valves and III defaults to OEM.
Old 10-12-2020, 06:23 PM
  #340
Ledfoot
Ledfoot's Avatar
I didn't read every post in the thread (apologies in advance if this is a repeat) but the other benefit of the valve controller is that it stays set when you shut the car off. Now I only have two buttons to push when I start-er up.
Old 10-13-2020, 12:48 PM
  #341
Poupon McArr
Poupon McArr's Avatar
Exactly, the OEM button is just about useless
Old 10-13-2020, 08:08 PM
  #342
Larry Cable
shame they did not extend its abilities to also retain other center console switch positions like A S/S also...
Old 10-14-2020, 06:30 PM
  #343
bvita
bvita's Avatar
Anyone in SoCal have a recommended installer, or a possible dealer?
Old 10-14-2020, 07:04 PM
  #344
Soul Performance
Basic Sponsor
We have a bunch of people we work with. PM me your exact location I’ll give you some options
Regards,
John
Old 10-14-2020, 07:25 PM
  #345
tdlondon
tdlondon's Avatar
I know Porsche of Santa Clarita does install aftermarket components. Talk to Michael Holland.
CDACH (10-16-2020)
Quick Reply: SOUL | 718 GT4/Spyder Exhaust Development
