Exhaust flap switch
#46
Silence before mod and very quiet after mod.
#47
Not the way to go in my opinion. Disconnect the hoses (I could do it easily by hand with moderate force). Insert grub screw in M6 size and thread it in
with a t-handle allen wrench. Use pliers to hold the hose while doing this. The grub screw should be inserted about 20mm into the hose, so you can
completely re-attach it on the exhaust valve. Same procedure on the other side.
Benefits: Invisible, no open ends to be sealed, cheap and quick. Also easy to undo by screwing the grub back out anytime
Peter
Peter
#48
Peter
Peter
Gook luck to any Tech in the future if this mod is forgoten about! haha
Also, what I did in the 80s to bypass power robbing emmisions plumbing.
#50
Peter
Peter
#51
Now, this is NOT good!! This is gonna drive me up the wall! No downshift-blip sound after 4k; and, not enough sound under 4k either! This is pretty f^&*k up!! So, fundamentally, the valve flaps are not the only ones suppressing the sound, during downshift-blipping. Not the GPF or pass-through inert filters because their effects are always present regardless of the RPM. So, even if you delete them, you are not gonna get that sound. Certainly not the exhaust. Is that engine management programming/ECU?
#52
Now, this is NOT good!! This is gonna drive me up the wall! No downshift-blip sound after 4k; and, not enough sound under 4k either! This is pretty f^&*k up!! So, fundamentally, the valve flaps are not the only ones suppressing the sound, during downshift-blipping. Not the GPF or pass-through inert filters because their effects are always present regardless of the RPM. So, even if you delete them, you are not gonna get that sound. Certainly not the exhaust. Is that engine management programming?
#53
#54
#55
Basic Sponsor
Remember you're hearing 2x 3cyl sound rather than 1x 6cyl sound with this stock exhaust arrangement. Think of it like the exhaust sound is akin to a pair of 2.0 3cyl engines, not really what any Porsche owner is looking for.
See image below for a visual demonstration. Green flow is valves open, the gasses will always take the path of least resistance. Red is valves closed.
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/975x975/jcrvsoem718_f302b34b77fbdff2811fb068c3922f3eee82e03e.png)
Removing the OPF will just accentuate the OEM exhaust note, it gets louder with the OPF removed but louder doesn't always mean better. In many cases, as with the 718 rear silencer arrangement, the sound is even more 'tractor' low frequency tone than ever.
Just a word of warning as to what to expect if you remove the OPF with factory exhaust or swap to any exhaust with no proper merge between bank 1-2 of cylinders.
Making an exhaust loud is easy. Making an exhaust add power, sound great and be quiet / loud when you want it to really isn't.
JC
WE'RE NO LONGER ACTIVE ON THE RENNLIST FORUMS - FOR ALL ENQUIRIES PLEASE CONTACT US VIA THE JCR WEBSITE BELOW
/ / / JCR PORSCHE \ \ \
contact@jcr-developments.com
Facebook | Instagram | Youtube
Croc999 (07-09-2020)
#56
Fully agree with comments above from JCR.
It will be interesting to see the above system with OPF/GPF bypass pipes. Maybe crazy loud because almost totally straight through with no muffler.
#57
Basic Sponsor
2017 RSR (pre LM) had the megaphones straight off the headers. So again 2x 3cyl sound, as per OEM 718 GT4 design.
2017 RSR (LM spec) gathered the tips at the centre so you hear the full 6 together. Note that this still has no merge but just graphically shows just how much difference it makes to the sound. With a merge the sound would be even more in this direction.
The latest gen RSR has side exits so even further accentuates the 2x 3cly sound track.
I'd challenge anyone to find someone who doesn't find the central exit sound the most desirable!
JC
Mcx (08-10-2020)
JCR-Porsche (05-01-2020)
#59
will report back on disconnecting the vacuum lines this weekend. I am really starting to think the 981 gt4 is the better car. If you just compare price when new, $86,000 for a base car without options including delivery compared to a 718 gt4 at $100,500 without options including delivery. Now you have to add at least $5k to fix quiet exhaust. So far I am really disappointed and wished I kept my stripper 981 GT4 that I sold a few years ago due to the hype the 718 GT4 was getting a 4 liter
#60
