Exhaust flap switch
#32
I received a quote from Cargraphic (350 euros excl placement) and a note showing how to install this. While I would not do it myself, this does not seem very complicated and fortunately does not involve any cutting of wires, etc. Essentially unplug a cable and then plug the Cargraphic thing in it. You would also need to screw the small Cargraphic grey box somewhere near the engine.
#34
I just did the valves mod (unplugged both hoses).
I really like it under 4000 rpms. Valves are always open, it’s 15%-20% louder than before.
You hear the downshifts a little more now. Is it a radical change: NO. Is it better: YES. Low end torque; I didn’t notice any change.
I suspect a very subtle resonance at highway speeds (80mph in 6th gear).
Bottom line: worth it. I’d recommend doing it on a lift (takes 20 min). See below how I attached the hoses
and does the mod change the character of sound or simply make it louder?
#35
i sealed the open ends with screws and attached the cables to the frame
#40
when you unplug the connection to the valves, the valves are ALWAYS open. The difference is significant under 4000 rpms. Above 4000rpms no difference at all.
#41
Thanks for the tip! Pulling the exhaust hoses will be the first mod I do to my GT4 when it arrives. Louder exhaust and free = no brainer.
I’ve never been under a GT4 before, or any Porsche for that matter, is it easy to determine which are the vacuum hoses? Would anyone who’s done this happen to have a pic of what to pull out?
Much appreciated
Much appreciated
#42
Much appreciated
Much appreciated
#44
In Switzerland, dealers here always tell you don’t touch it. Will it void the warranty? it depends on so many things. It’s a risk I will take. I think once I am sure I have found the best exhaust option. GPF delete seems the most sensible move...I am waiting for more options. Are you thinking of a specific exhaust brand?
#45
Being in Switzerland, you'll void the warranty and fail the emission test, by removing the GPF! Here in the US, we get a pass-through inert filter which still muffles the sound. I haven't asked my Service Adviser yet on the exhaust mods I'm planning on. So far, the vendors with options are: JCR, SuperSprint and CarGraphic. Tuners are catching up. Within a year, we would have many options fully flushed out and vetted. I'm intentionally delaying my allocation as late as possible; probably into MY22. Just trying to scoop up all the info I can since a good sound is extremely important to me!
By the way, do you get sound from downshift-blipping after 4k? The valve flaps only address until 4k as you noted. So, if there was no downshift-blip sound before, after 4k, you still wouldn't have now, after the mod, right? Thanks.
