718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Another exhaust sound data point
Old 07-21-2020, 10:51 AM
  #556
2XIPA
2XIPA's Avatar
I wonder if a replacement for the GPF only becomes available not the full pipe. Interesting to hear one if made. Perhaps an even lower cost alternative. Although I must say the current options (especially the Soul to me) look and sound awesome.
Im not really going to concern myself with it until I get my car and have a chance to experience what it sounds like myself.
Old 07-21-2020, 10:53 AM
  #557
Motoss
Motoss's Avatar
Originally Posted by Mansour
I've disconnect vacuum lines from my Spyder and can confirm there is no drone, and the sound is improved considerably.
Will this create any sort of warranty issues down the road? Are people reconnecting them before dealership oil changes?
Old 07-21-2020, 12:08 PM
  #558
F1-GT
F1-GT's Avatar
+1. I'm very curious about this as well
Old 07-21-2020, 12:20 PM
  #559
Westcoast
Westcoast's Avatar
Received 4,711 Likes on 2,741 Posts
Given the design of the OEM OAP, there is not much point in making a new configuration just for the GPF canister itself, when you look at the pipe connection to the GPF it is welded.
Thus far all of the replacement GPF elimination OAPs simply insert pipe between the flange that bolts to the back of the cats and where it bolts to the muffler, with their proprietary designs of course.
No, the simplest idea here is what you are seeing, below is a side-by-side of the OEM along with the Soul unit you mention, clean and easy to install.
2XIPA (07-22-2020)
Old 07-22-2020, 01:44 AM
  #560
incursion
incursion's Avatar
alexk79 (07-22-2020)
Old 07-22-2020, 02:49 AM
  #561
Mansour
6th Gear
Mansour's Avatar
Suggest you discuss the mod with your service advisor to confirm any warranty issues.
Croc999 (07-22-2020)
Old 07-22-2020, 03:37 AM
  #562
alexk79
alexk79's Avatar
Originally Posted by incursion
Thanks for posting my video.
Old 07-22-2020, 07:20 AM
  #563
works_team
works_team's Avatar
It does drone a bit on my GT4, between 2.5k and 3.2k rpm approximately. That is when you drive “cruise mode”, not “racing mode”.
Old 07-22-2020, 01:47 PM
  #564
John@Fabspeed
Basic Sponsor
John@Fabspeed's Avatar
Hey Guys,
Phil here from Fabspeed. We have designed our over axle pipes to 2.5" inlet pipes for maximum flow.
Over Axle pipes remove and delete the Gasoline Particulate Filters, GPF, found on all GT4, GTS, Spyder, and 4.0 liter GT4 cars worldwide.
To meet stringent Euro 6 emission standard and European models of the 718 Spyder and Cayman GT4 refitted with two particulate filters one for each of the cylinders
Euro 6 allows for only one tenth of the previdusty allowed particulate emissions On European models the exhaust gases are forced through the filter wall trapping soot that is burned off later US models Use a straight through filter design without the expensive, soot trapping precious metal coating. This makes them inert and nothing more than Sound attenuators. Porsche keeps these on US-bourid 718 Spyder and Cayman GT4 so It doesn't have to change the specification of the muffler"
As of now here is our explanation of how we created our OAP.
Fabspeed OAP explanation
Here are some sound clips of the over axle pipes:
Stay tuned for the full exhaust system.
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
Old 07-22-2020, 10:02 PM
  #565
_nosubstitute_
_nosubstitute_'s Avatar
Originally Posted by Phil@Fabspeed
Hey Guys,
Thanks Phil, but are you able to post a video where the PSE is always open with OPF only mod applied? The video doesn't do a good job showing us what OPF delete sounds like on its own because the PSE valves are closed up to 4k RPMs and by the time it opens up the car is too far to hear it properly. The rest of the video then shows it with the rear exhaust can mod, so it doesn't really give us a full understanding of how Fabspeed's OPF deletes sound on their own.
Old 07-22-2020, 10:18 PM
  #566
TomTarzian
TomTarzian's Avatar
Perhaps I missed this, but isn't there a reason why Porsche has the valves closed at various times? Could keeping them always open somehow actually be detrimental?
God bless,
TT
Old 07-22-2020, 10:22 PM
  #567
Jim Rockford
Jim Rockford's Avatar
God bless,
TT
Euro noise regs.
Then they give the same programming to rest of world so that there’s no obviously more desirable version of the car sold one place over the other. There are different theories, but that’s mine on why NA gets the same programming. That’s also my theory on why NA gets stuck with a dummy OPF.
The following 2 users liked this post by Jim Rockford:
Motoss (07-22-2020), wizee (07-22-2020)
Old 07-22-2020, 10:45 PM
  #568
wizee
wizee's Avatar
Originally Posted by Jim Rockford
Euro noise regs.
Yup. New European regulations require the exhaust volume in the loudest mode to be below a fairly low threshold when accelerating at wide open throttle from 50 km/h for a brief test duration. Thus, Porsche programs the valves to be closed below 55-60 km/h.
Motoss (07-22-2020)
Old 07-22-2020, 11:01 PM
  #569
Sausage416
Sausage416's Avatar
My cargraphic opf delete came in before the muffler ,I couldn’t help but to install the opf delete first. Noticeable rumble right away ,and quite a bit louder even with the oem muffler. With valves closed ,it’s oem quiet ,with valves open you get a nice aggressive flat6 howl. With the delete the cabin sound is glorious.
Old 07-22-2020, 11:50 PM
  #570
_nosubstitute_
Nice, thanks for reporting back. Are you impressed enough with just the OPF delete pipes? Can you post a video?
Quick Reply: Another exhaust sound data point
