My Trailer Diary
Old 02-28-2017, 01:27 AM
  #496
zip465
zip465's Avatar
Originally Posted by nxfedlt1
how do you all have your nitrogen set up? I too have a CS and am going to build yet another trailer.....there should be a hand me down program...I'll get inline behind you guys..
Might do something like the image below from Paoli (80L bottle, F4 reg, and trolly kit), but will likely just go the Harris Motorsports reg with a trailer mounted bottle.
zip465 is offline
Old 02-28-2017, 03:26 AM
  #497
24Chromium
24Chromium's Avatar
Originally Posted by zip465
Question for those with a TPD trailers and a GT4 or Clubsport what size/model race ramps are you using
I've got the longest 2-piece Race Ramps. I am looking at their web site, but I can't remember whether I've got the 10" or 11" rise. I will say this, the notch in the tall end of the ramp, where you place the gate, is too deep. I ended up gluing a piece of wood in place so as to fill the gap. I just cut it on a table saw to the correct thickness so that my trailer gate lies flush on the ramps.
24Chromium is offline
Old 02-28-2017, 10:11 PM
  #498
Tom W
Tom W's Avatar
I don't have a GT4 or CS, but my TPD has the aluminum ramps that TPD provides and they work great for my car (1.75" clearance under the nose). I just needed slightly larger rubber bumpers to raise the door a tad and I get it to clear. I like that they stay attached to the door and I don't have to mess with moving and storing them.
I have a 150 nitrogen bottle mounted by TPD. I wish that they used a bit less offset from the trailer wall, but it works well for my air jacks. It lasts just over a year (as mostly JWE is supplying the air). This bottle is as wide as I can go and still get the car to fit past.
Tom W is offline
Old 03-02-2017, 02:45 AM
  #499
mooty
GT3 player par excellence
mooty's Avatar
Received 5,482 Likes on 2,269 Posts
mount the can near the front of the trailer. this way you dont have to drive PAST the can. run the hose out the front door of trailer so u dont need the gate open all the time
i use 6' and BEARLY clears. i also tried 2x ramp like chromium. too much work. i am done loading the entire rig in 20 min after the checker flag. the 2x ramp takes much longer to put together. u will make it with 6' i am sure. i have G rated tires on GN traier so i am at least 4" higher than your 24' bumper pull. if u can't get the car in, then i think uyo are below legal ride height!
the alum hinged type that tomW has is very nice. BUT DO NOT FORGET TO STRAP IT. my friend did and he had no bumper after we opened the gate upon arrival.
chris, the nitro can you showed is too small. you need one every weekend if that's the size of a regular diving tank.
mooty is offline
Old 03-02-2017, 07:23 AM
  #500
Phokaioglaukos
Phokaioglaukos's Avatar
What I did, BUT you'll need a looooong hose for crowded paddocks where you cannot pull the car alongside the trailer. Get a pressure washer hose: higher pressure rating and easier to find.
Phokaioglaukos is offline
Old 03-11-2017, 11:01 PM
  #501
mrsullivan
mrsullivan's Avatar
Have very much enjoyed reading this thread. Going to pull the trigger on a new trailer next week.
I am paralyzed between two choices. One obvious/conventional, and the other is a "hear me out" option.
Uses: hauling cars to Porsche/other events in Texas and California (PCA stuff, Luftgekuhlt, etc.). I am not a serious racer, I do some Porsche DE, but also lots of car shows and events. I usually have 2-3 "toy" cars and cycle between them, etc. Also have offroad stuff - UTVs, ATV, trial bikes, etc.
Truck: RAM 3500 cummins/aisin
Budget: ~ $20k
Final candidates:
1) obvious choice - ATC Quest 305 w/escape door, 24 ft. $20k + TTL. Everyone here knows this trailer pretty well I guess. It comes fully equipped and very finished out inside. I like the brand reputation, history, etc. I wonder if it is too much/too nice for what I will be using it for (or more accurately what I will not be using it for - countless hours in it at a race track with advanced PCA club racing, etc.)
2) hear me out choice - Sundowner XTRA Series 24ft v-nose. This brand is well known for horse trailers, but probably not as much in the auto community. This trailer appears very well made. .50 aluminum skin instead of the .30 on the ATC. Extruded aluminum floors instead of the rubber coin of the ATC. 16 inch wheels/tires instead of the 15s on the ATC. Heavier D rings. Larger door, list goes on. Much less finish out inside, doesn't come with cabinets, less LED lights, no battery/110 system, etc. Doesnt have escape door. It is basically a raw frame trailer. But it seems to be exceptionally well constructed. $16k+TTL
I am wondering if I am better off buying the sundowner. Easier to wash mud/oil/etc out of it and seems to have put more $ into the actual structure vs finish out in the case of ATC. With the $4k differential, I could have some things welded into the trailer and set it up just like I want.
Thoughts? Anyone have experience or an opinion with the Sundowner brand? Both trailers have roughly same weight and ratings, same axles, etc.
Here are some pictures of both
mrsullivan is offline
Old 03-12-2017, 08:23 AM
  #502
jlanka
jlanka's Avatar
I have the ATC. I think the sundowner would be fine. No escape door but you can live with that. You can install cabinets.
jlanka is offline
Old 03-12-2017, 09:14 AM
  #503
mrsullivan
mrsullivan's Avatar
The escape door would be nice. But overall the Sundowner just seems better construction and higher end materials. Its just not finished out. May end up costing the same or more when finished adding cabinets, lights, etc. But .50 vs .30 aluminum, 16s vs 15s tires, extruded alum floor vs rubber coin, etc.
Worried maybe no vent on the Sundowner. I dont see one in the pictures and I cant remember from when I visited in person. But I suppose that can always be cut/added also.
Old 03-12-2017, 11:10 AM
  #504
jlanka
jlanka's Avatar
I would actually prefer exposed inner walls also. Makes it easy to add stuff
jlanka is offline
Old 03-12-2017, 12:32 PM
  #505
ShakeNBake
ShakeNBake's Avatar
Is it wide enough? Looks narrower between wheel wells than the ATC. Make sure you can fit the hips of an RS through there!
ShakeNBake is offline
Old 03-12-2017, 01:04 PM
  #506
linzman
linzman's Avatar
Except it makes it easier to dent the outer aluminum, from the inside. I like having the inner skin too, and it's easy to find the studs to install stuff.
linzman is offline
Old 03-12-2017, 01:15 PM
  #507
grrrmonster
grrrmonster's Avatar
Can the sundowner handle the weight?
grrrmonster is offline
Old 03-12-2017, 02:39 PM
  #508
jlanka
jlanka's Avatar
you got a point there Norton...
jlanka is offline
Old 03-12-2017, 03:24 PM
  #509
mrsullivan
mrsullivan's Avatar
Has the same 5200 pound axles, same weight load ratings, etc. empty, it actually weighs about 300 pounds more than the ATC, even though it is not trimmed out. From looking at it on the inside, I think this is a combination of the aluminum floor and in general heavier gauge materials.
Same dimensions also, length width etc. Lose a little bit of space in the front because of the v nose but I feel like that would be a really great place to put cabinets.
still torn, I know that ATC is one of the watermarks
here is a link to more info on the sundowner trailer
http://www.sundownertrailer.com/tlr-XtraTransporterBP.html
Old 03-12-2017, 03:33 PM
  #510
mrsullivan
mrsullivan's Avatar
one more
Quick Reply: My Trailer Diary
