AIM Solo DL Brake pressure 981
#46
Basic Site Sponsor
Basic Site Sponsor
Received 2,837 Likes
Which connection, CAN or OBD-II?
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#49
Basic Site Sponsor
Basic Site Sponsor
Could we schedule an online session next week or the week after, whenever you are at your car? We'd use TeamViewer so I can see what's going on. You would need to connect your laptop to the Solo DL and have it connected to the car with you actuating the brakes.
That's very interesting. I have tested a number of 2015 and 2016 981 cars using the 991_981_OBDII protocol using an OBDII connection to the Solo DL just last week and could not get four wheel speeds, fuel level or brake pressure, after being told of the same problem experienced by a number of Cali 981 owners....
Not sure why yours works and others don't, including the ones I tested. TIA.
#51
Basic Site Sponsor
Basic Site Sponsor
I would have imagine it's a different ECU (3.8 vs 3.4), so perhaps better alignment with the protocol that I KNOW works with all the 991's I have plugged it into and sold equipment for use.
Perhaps you could PM me or send me your email so I could ask a few more questions.
Thanks!
#53
Basic Site Sponsor
Basic Site Sponsor
#54
Problem signature:
Problem Event Name: APPCRASH
Application Name: AiMRS3-32-ReleaseU.exe
Application Version: 1.0.0.1
Application Timestamp: 53ba9998
Fault Module Name: AiMRS3-32-ReleaseU.exe
Fault Module Version: 1.0.0.1
Fault Module Timestamp: 53ba9998
Exception Code: c0000005
Exception Offset: 00409879
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Read our privacy statement online:
http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
#55
Basic Site Sponsor
Basic Site Sponsor
Got it. The Smarty Manager 2 is now crashing anytime I connect the SmartCam HD or if I press the update arrow. Not sure if I will be able to get video showing the parameters if I can't fix that. Worked great in October.
Problem signature:
Locale ID: 1033
Problem signature:
Locale ID: 1033
AIM list serve. New issue.
#56
Thanks for letting me know about the software issue.
Ok, I have a bunch of test data but usually just use the smartycam info. What do you want to see from the Solo DL? I'm a newbie with this. Thanks.
#57
Basic Site Sponsor
Basic Site Sponsor
Select one of the longer ones (should be a lap count MORE than 1) and double click it or select and "Open Test" on the bottom of the page.
Then, by default it will open the fastest lap. You'll have squiggly lines across the bottom and "Measures" or channels on the left edge.
Select by pressing the channel that says "Brk Pre" or something like that. If you don't have a flat line on the right half of the screen for THAT measure, then it works.
PM me or take a screen shot with more questions.
Other thing you can do is in the "Test database" listing of all your runs, you could right click a longer file and select "Email test." Please send it to my email listed at the bottom of my website in my sig. I'll share what I see...
#59
Basic Site Sponsor
Basic Site Sponsor
I'll find a local GT4 to test the direct wire CAN solution, which has worked on other 981's.
