So what did you do to your 928 Today......
#166
You guys in the US are lucky.... UK premium unleaded (97-99 Octante ) is approx £1.35/litre or equivilant of $8.50-9.00/gallon. A massive chunk of that goes to the government and fuel duty is set to rise again later this year
Stone smashed the for light lense on the drive to work this morning, it's going to be one of those weeks methinks!
#167
Id rather pay more to have a decent mass rail system like I use from Gosport to central london everyday when I make my trips there for work...rather than the drive.
928 content:
Im about to drive to work on roads with the quality expected from a lack of fuel taxes to repair on a regular basis.
#168
Our politicians started to read your paper...
We're working on it...
http://dfw.cbslocal.com/2011/02/13/s...-gas-guzzlers/
#169
On Saturday:
Replaced broken door handle assembly
Replaced the window guides
Installed new felt on the window guides
Replaced broken coin holder
still to do:
Replace broken aero mirror motor on driver side.
still to do:
#170
So how tough was it to replace the felt? Any special "gotchas" you need to look out for when doing this. My felt has gouged my window tint so I need to replace them.
#172
Remove inner door panel.
Remove inner window sill seal (it just pulls off).
Now you can access the felt guides.
Remove old felt and use a good wheatherstripping glue or contact cement to install the new felt.
I bought a small sheet of nice thick felt at Home Depot in the fasteners/picture hooks/furniture glide pad section and just cut pieces of the corresponding length and width.
#173
Supercharged
Fired up the monster with the open headers and woke up the neighbors. Noticed a slight leak at the oil cooler - snugged up the bolt that holds the hoses in place and not it appears to be happy. Need to get it to the exhaust guy later this week.
#174
drove my son to his scout meeting at the new police station for a tour...
The shark got LOTS of attention from the scouts, their dads, and the officers on hand..
not sure if that was good or bad.
#175
Aero mirror...
What's suspect the motor, moving gears or did you just brake the glass?
#176
The plastic tabs that connect the motor to the mirror glass assembly are broken. Need to replace the motor. I have one on hand, just need to figure out easiest way to do it.
#177
Will be interested what happens on yours Randy. I have a new piece of glass I've been trying to install ... my glass assembly seems stuck to the motor or whatever ... turned the little toothed part clockwise but it won't let go of the glass ... those little tabs are really hanging on for some reason ...
#178
Chronic Tool Dropper
More alignment adjustments... Rear this time
Working on rear wheel alignment today, trying to get rid of the slight tendency to the right shoulder without cranking up caster on the left front. I haven't payed attention to rear toe enough, according to the measurements, but more important is getting the two sides to match. (!!). Too much total toe in the rear, and the two sides not the same. So I cleaned up the adjusters, set the lasers to 'stun', and got them both dialed in just perfect in less than 20 minutes. Time for a test drive, and re-attack the front adjustments if needed. Odd part of the exercise was that the left rear was toe'd in more than the right, yet the car still tended right. I hope the test drive doesn't prove that the factory tweaked the rear alignmnet to make up for something in the front. Film at eleven, after I get the suspension settled again.
#179
Stunning?
I'm interested in your findings I may have the same issue but don't have time to investigate it myself right now.
Sound like you are using you two lasers at the same time (are they HF if so what model #) what do you mean by 'stunning them.
Thanks HK
#180
Good luck with yours
