Old 09-05-2016, 06:59 PM
  #7666
odonnell
odonnell's Avatar
Put the NA up on jack stands to do timing belt and water pump... It's been 3.5 years since I did the belt and no history on the WP. engine rebuilt in 2006 according to service records.
Water pump had a casting date of '95....it still worked fine albeit there was a few thousands of radial play in the bearing.
Old 09-05-2016, 07:06 PM
  #7667
KVDR
KVDR's Avatar
Bought this pair of knock-off Turbo emblems on eBay, $20 USD shipped.
No plans to use them, but the price was right.
http://www.ebay.com/itm/272178937437?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 09-06-2016, 07:11 PM
  #7668
Kurt R
Hates Family Guy
Kurt R's Avatar
I replaced the disintegrating sun visor clips with ones from a VW. I painted the covers black with Krylon Fusion, left the clips gray.
Old 09-11-2016, 10:35 PM
  #7669
odonnell
odonnell's Avatar
Showing the NA some love, been dragged out due to hectic work schedule.
New coolant expansion tank
A few new coolant hoses
FMS, oil pump drive gear, green O ring
New rollers, timing belt, water pump, new hardware for everything including crank bolt
New steel control arms with poly bushings, new ball joints, and new hardware all around
New sway bar center bushings, all new hardware all around for sway bar connections
Misc. new hardware for stuff around the front of the engine that I thought looked ugly. It's cheap and OEM-ish from Belmetric.
The 951 recently got some goodies too. A stainless steel shifter insert, stainless steel sun visor clips, and some 14point7 "solid series" gauges in a LR 3-pod surround. Pics soon.
Old 09-14-2016, 03:10 AM
  #7670
Arominus
Arominus's Avatar
I put the s2 on stands so i can drain the coolant, i've got a leak in the heater core or failed o-rings at the heater core inlet. I really want it to be o-rings, i don't want to pull the dash again.
Old 09-14-2016, 03:30 AM
  #7671
KVDR
KVDR's Avatar
Washed and waxed the car. Original paint and it has it's flaws, but cleans up nice.
Old 09-14-2016, 03:44 AM
  #7672
kyle a. w.
kyle a. w.'s Avatar
Got a new windshield installed. Mine got cracked from something on the road. I can see so much better. Original was pitted and and had a bad tint job across the top from a previous owner.
Old 09-14-2016, 02:34 PM
  #7673
dmjames
dmjames's Avatar
Swore repeatedly at the stupid retaining clip for the heater control valve's bowden cable. Lost both the original one that used to be on the car AND the replacement one. Starting to think I should just disconnect the thing and change the heat setting with a $*#$ing screwdriver, because that's probably easier than getting the stupid cable reattached properly.
Old 09-14-2016, 02:41 PM
  #7674
KVDR
KVDR's Avatar
Ordered an A-Tune and MBC from Lindsey Racing, and then a used LR DP wastegate from Lart.
Old 09-14-2016, 04:46 PM
  #7675
pdxfj
pdxfj's Avatar
Took mine through emissions testing so I could get new registration. Went through just fine. Good for another two years.
Old 09-15-2016, 06:03 AM
  #7676
FourtyFourNZ
FourtyFourNZ's Avatar
Finally got around to putting the finishing touches on the gauge panel
Old 09-15-2016, 01:57 PM
  #7677
drive924S
drive924S's Avatar
Today I registered on Rennlist. Time to learn about 924S
Old 09-19-2016, 02:56 AM
  #7678
morghen
morghen's Avatar
Really nothing to the cars, but i finished the wooden deck in front of the livingroom and had a small dinner party around the 931.
Old 09-19-2016, 10:07 AM
  #7679
V2Rocket
V2Rocket's Avatar
fixed my front spring that had been installed upsidedown
and replaced the oil sender...
Old 09-22-2016, 12:24 AM
  #7680
KVDR
KVDR's Avatar
Halfway through hatch re-seal. Ugh.
I want it to look like this one when I'm done.
