PCA Rule Changes
#106
Those pins don't stick out very far. I have the numbers written down somewhere. I think the total height of pins plus rails on these sliders isn't really that much more than the various older styles from Recaro and others. For those cars with branded uprights from companies like OMP, Recaro, Sparco, Speedware and Brey Krause, there may be opportunities to get the difference back by using existing lower holes or drilling new holes that are lower.
Using any of the sliders in older cars requires fab work. And for those that are so tall that every 1/4 inch matters, they can choose the Sabelt units or work with scruts to identify something else acceptable
And of again, the new rules are only for those without seat back braces so this might be much ado about nothing.
One shop in my area that I have mentioned previously has a pretty extensive experience with these pin-style sliders for a variety of cars and drivers. They generally don't use seat back braces, likely because they believe that the seats weren't tested by the manufacturers with braces and may be safer without them.
#107
The Boxster units, like the one in the pix Jack posted, raise the seat brackets 4.5-5 centimeters above the floor boards. This is before bending the front eyelet. The pins themselves are, I guess, 6-8mm.
#108
The reason for the increased height is the actuator mechanism on the Porsche sliders is high. This prevents being able to drop the seat low between the side mounts. The JWE system adresses this by adding extensions off the back of the Porsche slider. By shifting the seat rearward on the slider, it can be lowered a bit.
I have a few pictures that illustrate this well, but I don't want to post them without Mike's permission.
#109
Jack, did you buy the extenders from JWE? Do them come as a 'ready to install' package. Bolt on? Are the BK bracket different from others making them a requirement for the system to work?
#110
So I ordered the BK mounts (pictured). They are clean and do not use the "extensions" to the sliders like the JWE system. But my seat will no doubt be higher than one using the custom JWE extenders (and lower JWE side mounts). Comparing my mounts with Mike's pictures, it looks like a difference of ~2-3 cm.
#111
<------------------------------ Yonker, congrats on the GT4S points championship, AGAIN. And thanks for inviting me to be your date (b$tch) for the sebring awards dinner AGAIN. I'll even carry your trophy for you.
#114
PCA GTC5 Rule changes for 2015
I'm wondering about the changes to GTC5 rules for 2015. Will GTC5 finally get added to the rule exceptions that GTC4 enjoys?
For example, the rules currently do allow GTC4 but NOT allow GTC5 cars to:
3A) Use aftermarket brake rotors
3E) Relocate battery to footwell
4L) Use aftermarket dampers
4M) Change master cylinders
3) Use third party, equiv. wheels
Frankly, when I've raced in GTC5 in western region events, almost everybody in the paddock has relocated their battery, or replaced it with a LiIon unit. And many cars have aftermarket dampers, because IMSA, Pirelli GT3 Cup & POC all allow this modification. PCA is the only one that doesn't technically allow it.
I've never seen a driver DQed for these infractions. The inference is that the stewards consider the GTC4 rules apply to the GTC5 cars, just that the official rules haven't been updated yet. Does anyone have a plan to do this? or are there objections?
[QUOTE=jenk12m;10889086]PCA Club Racing Rules Changes For 2014
The Rules Committee has adopted the following rules changes for the 2014 racing season.
GTC
31) Consumables, as specified in the second paragraph of the Stock Cars rules, are free as long as they cannot serve to increase the car's performance.
32) The 2014 Cup cars, in GT America trim, will race in GTC6. Whether these cars, in European Supercup trim, will run in this class as well remains to be decided.
GTC
