Testing at Thunderhill
Old 04-06-2011, 10:31 PM
  #106
SundayDriver
Lifetime Rennlist Member
SundayDriver's Avatar
Originally Posted by Veloce Raptor
Yup. It's all about the clutch packs.
No, no, no, no, no.
You need a flat HP curve, with lots of tire slip so the clutch packs will convert pv=nrt into downforce on old tires and worn out shocks so you can take an early apex.
Gee, that seems too short, so...
No, no, no, no, no.
No, no, no, no, no.
No, no, no, no, no.
No, no, no, no, no.
No, no, no, no, no.
No, no, no, no, no.
No, no, no, no, no.
Old 04-06-2011, 10:33 PM
  #107
Greg Smith
Greg Smith's Avatar
Post.
Of.
The.
Year.
Old 04-06-2011, 10:39 PM
  #108
mark kibort
mark kibort's Avatar
mark,
if you had a limit of HP would you want a flat hp curve or a flat torque curve? Its a simple question. state the reason if you can.
Mark
Originally Posted by SundayDriver
No, no, no, no, no.
Old 04-06-2011, 10:41 PM
  #109
SundayDriver
Originally Posted by mark kibort
mark,
Mark
Hmmm. Tough question. I vote for a sense of humor.
Old 04-06-2011, 10:44 PM
  #110
Veloce Raptor
Veloce Raptor's Avatar
Received 1,610 Likes on 836 Posts
Vote? I vote for SundayDrover for President.
Old 04-06-2011, 10:46 PM
  #111
SundayDriver
Thanks. I do need time to work on my golf game.
Old 04-06-2011, 10:59 PM
  #112
mark kibort
VR,
Ive heard most (or i know some) modern Dragsters use automatic transmissions! At first glance , they look to act a lot like CVT, but I dont know for sure.
you tell me, know it all boy!
Tire slip is pretty substantial
Here is some slow mo
http://www.youtube.com/watch?v=XttOe4rerLo
Old 04-06-2011, 11:02 PM
  #113
mark kibort
Really?? wrong again? Hmmm,I thought I read that most modern dragsters use torque converters. But, you seem to know what you are talking about, so....
Dont slip tires much?? 2:1 isnt a lot??
check out the slo mo video.
Originally Posted by Matt Romanowski
Wrong once again. Dragsters use regular transmissions and slip the clutches a bunch. They also change the ignition and fuel curves to reduce power. Oh, and they don't slip the tires much.
Old 04-07-2011, 09:49 AM
  #114
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
So you want to talk about Pro Stock Cars or Dragsters? Pretty bid difference. 300" long vs. about 120". 8000 hp versus about 900 hp. 320 mph versus 200 mph.
I think the last top fuel dragster that used a slider clutch ran in the early '80s. Pro Stock CARS still shift, but we are talking about DRAGSTERS.
Now if you are going to claim you where talking about Comp, Super Comp, or something like that, it's different, but as you know, most people don't refer to those as dragsters.
Old 04-07-2011, 01:02 PM
  #115
mark kibort
Well, there is the most common problem of the internet discussion. terminology! yes, I was talking about automatic transmission, because that is how it relates to the CVT, or IVT. Dragster, pro-stock, .... they are all dragsters to me. IM not a drag guy, I just know they go real fast, burn a ton of gas and they alll talk about how much power they have!
Old 04-07-2011, 01:33 PM
  #116
mark kibort
Scott,
You never answered the question!
Would you want a flat hp curve vs a flat torque curve, given that you couldnt increase the HP or had a limit on HP set by a series you were running in. (i.e. HP weight ratio, etc)
Old 04-07-2011, 01:54 PM
  #117
winders
winders's Avatar
Scott,
No matter what I or anyone else says, you are going to come back with a 7 trillion word dissertation on how you are right. Discussing anything with you is completely pointless.
Scott
Old 04-07-2011, 02:06 PM
  #118
mark kibort
Why, because I disagree with you? Thats not true Scotty! You challenged me and pointed out some things that you said were "fantasy" I merly responded with some factual information.
Dont chicken out and run away, when you are the one that really came back with the rude response equivalent to, " you are wrong". If so, prove it.
First that striving for a flat HP curve is better than striving for a flat torque curve. I live this with my car, so it is reality. its a very flat HP cuve. IN actuality, most HP /torque curves look near the same. the V8s tend to have more of a mid range hump (more torque) and fall down from there. this is good though, as it boosts the mid range torque and mid range HP. after all, where we end up after a shift or off a turn, is what we care about. usually that is 70% of redline worst case.
Here are two curves that really speak well to the discussion.
A V10 viper vs a F-6 GT3RS . both have near the same shape curves, but the point of interest is that the Viper, even with its 150ft-lbs of additional torque, would put down near the same torque to the wheels at any point on the track. Also with a close ratio gear box, any diffeences would be reduced. Its the reason these cars can compete in ALMS, WC and other series racing.
also, here is also a dyno run of a GT3, but with a change in hp curve shapes. what is the effect of the change and what one would you want if you were using an engine like this in your race car?
Scott
Old 04-07-2011, 03:00 PM
  #119
Matt Romanowski
Rennlist Hoonigan
I don't like 928s, so it's the same as saying your car is a water buffalo that can't get out of it's own way. Might as well be true.
Old 04-07-2011, 03:31 PM
  #120
LoanWolf
LoanWolf's Avatar
Scott
That is priceless!!
Quick Reply: Testing at Thunderhill
