PERFORMANCE FRICTION pads - who uses them? A question --
#63
Direct Drive Version 1 rotor hat
#64
Direct Drive version 1, looks like this:
http://www.hmsmotorsport.com/store/b...3-direct-drive
Whereas, Direct Drive version 2, looks like this:
https://rennlist.com/forums/6488888-post11.html
Thanks,
Mike
Thanks,
Mike
#65
01 - higher initial bite, higher torque, better modulation and release than the 97's...it just doesnt last as long as the 97 compound
06 - very similar to the 01's but not quite as much bite and torque...it's an endurance compound and last a lot longer than the 01...imo, much better endurance compound than the 97 compound
Also I might add that the only reason I took the 01s out of the car was to test the 06s out. Still using the 06s.
#66
Dave is correct. One quick note on the 01 compound is they still last longer than most pads out there since they are usable down to the last bit of pad material. I still have a set of 01s from my GT3 with half the pad material left. This is after about 600 track miles and about 1000 street miles on them. So for those that like the 97s you will like the 01s a lot better. There is a big difference in the improvement of the pads
Craig?
#67
Dave is correct. One quick note on the 01 compound is they still last longer than most pads out there since they are usable down to the last bit of pad material. I still have a set of 01s from my GT3 with half the pad material left. This is after about 600 track miles and about 1000 street miles on them. So for those that like the 97s you will like the 01s a lot better. There is a big difference in the improvement of the pads.
#69
The 06's do last a long time on the track.
#71
Do they make a DD for a Big Red equipped 965 size rotor?
