View Poll Results: Who won the debate: MK (HP) or VR (Torque)
Mk won with a simple to understand concept that HP determines torque at the wheels at any speed.
25
17.48%
MK won: When comparing equal HP cars, the one with less torque COULD be better on the road course.
6
4.20%
VR won: When comparing equal HP cars, the one with more torque is better on a road course.
44
30.77%
Neither, as physics dont apply to race cars
18
12.59%
I don't want to open this can of worms again!
50
34.97%
Voters: 143. You may not vote on this poll
Poll: Who won the HP vs Torque debate?
#331
Still plays with cars.
Hacker, your graph is missing THE KEY component. Please add the curve showing the effects of a Type R sticker!
#332
[QUOTE=Rassel;6397800[/QUOTE]
Where did you get the Swedish flag in your signiture ? I like it !
My father was born and raised in Stockholm and I still have many relatives that live in Sweden.
#333
After looking at the green tune its pretty apparent that your BMW never sees any time below 4k rpm. Is that big wiggle due to the car oscillating on the dyno?
#336
Thats why this discussion is so good. Bryan would never spend any time below 5500rpm, right bryan?? remember you want to maximize HP not torque at any and all speeds.
mk
mk
#338
Then, you do get it now! good!
what did you think of the two equal HP, disparate torque engine curves?
see how the lower torque engine can make more rear wheel torque at any rpm now?
Mk
Mk
If the shape of the curve is the same then I do agree that you can produce the same rear wheel torque, but I can't quite wrap my around the viability of ever trying to empirically prove this. I can't come up with a solution that would make this possible. Theoretically it works but I'm not sure this is physically possible. Having two engines with identical shaped curves over different rev ranges, no way.
#339
Owns the Streets
Needs Camber
Needs Camber
I find there's lots of power under these curves.
PS. I think, I'm not sure, but when MK says lower torque or higher torque he doesn't mean an engine that actually has lower torque or higher overall torque numbers. But where the majority of the torque is produced by the motor at certain revs. I think.
Maybe.
More overall torque. For longer rev range. More good.
Maybe.
#340
Administrator - "Tyson"
#341
Flag is just something I googled and added in sig.
If you like engines and visit Stockholm. You should pay Micke Svens a visit. http://www.spezialmotorer.com/
#342
I assume the wiggle is the car moving...I wasn't there when the car was being tuned.
