Anyone here use left foot braking????
#61
All great points and I understand for barber.
About RA though, for turn 2 would be under the assumption that you take 1 in 3rd gear and stay in third through 4?
What do you think about turn 5? Too risky w/ oversteer there? I dont down shift there. And 7 as well, since you already downshifted for 6.
For T5, I did a quick brake & downshift to 3rd then used all the track beyond the curb. I understand this may no longer be the fast way, though, after the repave. Nevertheless, I used to use 3rd to get a really hard launch over the crest, then up to 4th, then back down to 3rd for T6, then down to 2nd for T7, again to get that really hard launch out of there. It's all about exit speed!
#62
TD, this is true. When someone asks you what turns you like to LFB in and your not completely sure, then it has become part of your subconscious car control.
#63
I recently drove my front wheel drive minivan through a heavy snowstorm. My tires were low on tread, (I bought new ones before the return in the snow). I used left foot braking many times to straighten out the van on the highway. It was really fun. I was able to be smooth with the LFB as I've been practicing it a lot in the minivan on the street.
OK, that's with a front wheel drive. My 996 has been in the shop all winter, so my only LFB practice has been in the minivan.
This weekend I may be driving in RAIN on the track. If so, I'll use tires with decent tread. Lets say I've come into a corner to fast, am I correct that if I stay evenly on the gas, and briefly LFB, I'll have a better chance of making the turn? (Briefly LFB since I have a 996 and I don't want the gas to cut out).
If I GENTLY ease up on the gas after starting to LFB, will I have an even better chance of making the turn without a spin?
#64
I started a new thread "Rain track driving", after my last post above. I thought I could erase the post and keep the new thread. Must not be so. Sorry for any trouble caused by my mistake.
#65
King of Cool
If yes, I'd say no, because:
If you're in a corner where you are going too fast and are having a risk to run wide, easing off on the throttle is better way to slightly slow down as that tends to make car rotate. Of course applying brake it usually shift weight to the front (which makes car rotate better) but with gas on, not so much.
LFB in snow: even though you used to to straighten the car, with front wheel drive car is usually used to make the car turn. You do it by staying on gas and applying brakes makes the car turn because te rear wheels are stopping while fronts are not (because you're on gas).
This is why you see rally cars acclerating on a corner while brake lights are on.
Driving on front wheel drive car in snow is actualllly a lot of fun, you can be 90 degrees sideways and still straightn the car which with rear wheel drive car would be impossible.
