Massive crash at Laguna tody?
#181
This is exactly the problem. The safety system (lack of flaggers) sucks at your affordable track day. Despite your laudable professed approach to blind corners with unmanned flag stations you cannot count on other participants to share your risk management values. What if, despite reduced intensity, you spin after a blind corner/elevation change and someone comes over the top and t-bones you? The underlying philosophy of a safety system is to assume that human error is will occur. What you are proposing is that everyone can be trained to behave the same way which is statistically unlikely.
#182
Today, reading some of the above posts, it only makes me think that if these posts reflect the truth, we should all be more drastic on such case.
If, I mean, Really IF some of the post above are ending to be the truth, then :
I would be for the creation of a black list.
And, such list should not be at the Organizers level, but I think, as we mostly all use the same (great, very efficient) service, i.e.: Motorsportreg.com, I can only think that such list should be in the hands of this service.
There are tens of thousands of records in the system, each of which can be optionally shared with other event organizers. They can review those notes before accepting a registration to reduce the chance for one bad apple to go somewhere new and cause more problems. It's one tool that can help prevent negative outcomes but there are usually many causes behind tragic events and that makes them hard to prevent (if not this one specifically, generally).
I'm very sorry for everyone involved and especially the friends and family of the corner worker who was a local here in the San Francisco area. My heart also goes out to the driver who hit the corner worker as they will undoubtedly be traumatized.
#183
In this case
I dont believe a flagger at turn seven wouldve helped out I honestly believe I was the first one through the oil
coming down to turn nine there was no flag there when I passed Remember I was going at a greatly reduce speed (as I saw the oil all the way down the track).
figure its about what, four seconds from seeing The flag station at turned six and the flag station at turn seven?
#184
#185
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,496 Likes
I'm not proposing anything. Just trying to open eyes to the reality of hpde days not being the same as race days. I want flaggers at every station. Most of the time there is not. Because of this I've adjusted my expectations and driving style. Not to do so is dangerous.
#186
It might not have helped regarding the cars spinning. But it might have changed the actions of the flagger in 8. I have no idea what his intentions were and am not speculating. But if it was me without a flagger in 7 I might feel responsible for getting the warning out earlier and do something I might not otherwise.
#187
- Yes, about 5 seconds from T6 flag station going out of view until T7 flag station coming into view.
- The oil streak started 100 feet or so before the T7 flag station.
#188
Is it possible flagger Received a message from flagger at station six that two cars had passed at station and were on the way up to turn eight. ?
While I understand every second is critical in this case Im not even sure it wouldve helped.
Let me throw this question now where the two cars that were involved in the incident the leaders on track?
#189
Guy did the same thing with an old air-cooled 911 at the Summit PCA race three years ago down the front straight, online, and all the way around the track. Car in front of me rolled three times because of the oil right in front of my car. Destroyed the car but driver OK.
Driver of 911 never even came over to see how the other driver was.
#190
This was a sad event, however the sole reason the track worker got hit was because he was at the WRONG place at the WRONG time. We may never know WHY he was out on a 'hot' track however from all indications he wasn't at his designated flag station. Sad but true. He may have been a hero, trying to warn oncoming drivers of either the oil on track or the spun car, (in an attempt to help avert further collisions on track) or he may have been trying to assist the driver in the first wreck, we may never truly know. That said, everything that happened before the incident (e.g., drivers noticing the RWB's oil leak in the paddock, the driver of the RWB car staging and going out regardless, the RWB suffering major oil leak on track, the cars following the RWB losing control, the cars hitting the wall/barriers etc.) are all hazards of track driving. We may try to prevent/mitigate these hazards as best as possible but if the track worker doesn't leave his flag station, he would most likely be alive today. We respect and appreciate track workers immensely, however I would not expect them nor does their job description call for them to risk their lives to protect my property (our cars). They are there to communicate with us, and keep us safe, from the relative safety of their flag stations.
We cannot take the draconian route and look to impose overly restrictive conditions at HPDE events as a result of this sad and unfortunate incident.
#191
This was a sad event, however the sole reason the track worked got hit was because he was at the WRONG place at the WRONG time. We may never know WHY he was out on a 'hot' track however from all indications he wasn't at his designated flag station. Sad but true. He may have been a hero, trying to warn oncoming drivers of either the oil on track or the spun car, (in an attempt to help avert further collisions on track) or he may have been trying to assist the driver in the first wreck, we may never truly know. That said, everything that happened before the incident (e.g., drivers noticing the RWB's oil leak in the paddock, the driver of the RWB car staging and going out regardless, the RWB suffering major oil leak on track, the cars following the RWB losing control, the cars hitting the wall/barriers etc.) are all hazards of track driving. We may try to prevent/mitigate these hazards as best as possible but if the track worker doesn't leave his flag station, he would most likely be alive today. We respect and appreciate track workers immensely, however I would not expect them nor does their job description call for them to risk their lives to protect my property (our cars). They are there to communicate with us, and keep us safe, from the relative safety of their flag stations.
Well said, +1
#192
The two cars that were "totaled" and you guys wouldn't even be able to believe how one of them was able to walk away from the car . The car behind me winded up moving the concrete wall barrier by 3 feet and cracked it in multiple places. Porsche did a real good job building gt3 and gt3rs.
Almost makes me wonder why I bother with all that additional safety in my (much slower) car (just kidding)
#193
Same thing with the many coolant pipe issues that drivers keep ignoring. People who even had them fail don't even bother to do the fix, they just got the same ones put in under warranty... ticking time bombs. Not sure why I should bear the financial responsibility for other people's laziness/cheapness/stupidity? I know of far too many totaled cars because of coolant line failures....
Yes, this is Off Topic, but we can talk about it : i.e.: from our lovely supplier, Porsche AG,
In 2007, I bought a brand new Cayenne S. About 20k miles later : Coolant pipes blow up on the freeway (sure, towing, courtesy car, repair under warranty..).
6 years later, in 2013, I bought a Panamera 4S, ..about 20k miles later : Coolant pipes blow up on the freeway (sure, again: towing, courtesy car, repair under warranty..).
Same engine, same problem, and this did also happen to thousand other customers.
How many tons of coolant have been spread on public roads, (where bikers and other cars have went through, ..before our great supplier took action to fix the simple engineering problem of the cooling lines ?
No comment, Porsche AG is not any better.
#194
About Off Topic too, ..but and about the flagmen, (I consider that they are our Angels on track) and specially for the people that mention the lack of flagmen at "turn" 7 this sad day :
The 99.99% of the car drivers that I talk with just all praise about the Nürburgring, they all speak about this track as "THE" place to go !
Well, I have been there (on track) more than one time, and one thing that I can tell you is : I NEVER SEEN ANY FLAGMAN at any place THERE !
I do not know exactly how many curves there are, but one thing is clear, it is more than 100 and other thing is also clear: a good 50% of these curves are blind.
Not counting that the track is VERY narrow, and ..between the track and the triple rail (both side, all the way), you only have a little piece of grass, generally much less than 10 feets wide, ..and people still dream about going there !
..Not counting either, that on public days, you may arrive in a blind curve, ..to find things like a tourist bus, a moped or a old VW bug and etc..
Okay, fatalities at the Ring is VERY different too, ..but nobody talks/writes about.
Or: please, if you are crying about the lack of the flagman at "turn" 7 in Laguna Seca, stop to praise this stupid widow maker track that is nicknamed "the Ring".
#195
