Received my new PIWIS III
#1051
@orca15 You're welcome, glad it was helpful.
Re if a Hybrid requires a 12V power supply? You may require it, I have read about the 12V batteries dying in hybrids and pure electric cars and you dont want the voltage to dip while coding.
I ordered one of these power supplied from Amazon: Very nice unit that allows you to supply constant adjustable voltage at 100amps. It can also be setup as a 3 stage charger as well.
David
David
turquoise-m993 (12-19-2022)
#1052
#1053
I just would like to share that I got my PIWIS 3 from rnlst_log
Download the SW online and got the interface within one week.
Decided to buy a refurbished laptop on Amazon and recovery the image into SSD ... very easy process and the support I am getting is above and beyond.
If you are looking for PIWIS this is a great option.
rnlst_log (07-20-2022)
#1056
#1057
@rnlst_log could you PM please, I’m getting an error when trying to send a message.
looking to do some things like add nav in cluster and need to procure a piwis iii 😃
#1059
#1061
Should be there.
#1063
Where are you all finding the recommended current for your car on the battery charger/power supply? All I’m finding info for is trickle charge.
im going to order this for my 2017 Boxster base as I only have a 15A circuit to plug into. It looked like 75A is 13A and the 100A charger is 15A so didn’t want to risk tripping a breaker
#1065
https://www.amazon.com/PowerMax-PM4-.../dp/B01ER3LH6Q
siberian
