Received my new PIWIS III
#1111
Well if it's any consolation, I went for my courtesy service for the 992 and a gentle 700+ miles round trip. They couldn't even see or read my car with their PT3G to reset the SRI...I ended up doing it myself and sent them proof as well as a "courtesy VAL" file.
I did take me forever to do a VAL on my 992 as to TOWMBO'd 2020 Macan S, I was told to stop futzing with it as she got all the mods she wanted so I stopped working on it. Last suggestion is contact @rnlst_log for any tips I haven't covered.
siberian
siberian
#1112
I understand that trying to save money is a normal thing, especially with PIWIS prohibitive pricing. But don't you guys think that supporting russian hackers is a bit unethical given current circumstances? A part of every $$$ you send to users with +7 950 area code is used to build rockets. Think about it next time.
#1113
Many things are unethical, but let's keep politics out of this please. Thanks
siberian
siberian
#1114
It was in V or E mode?
Try to switch V mode if it was in E.
And use VAS-Wifi instead of USB.
Watch your voltage for stable above 12.4V.
#1115
it seems to fail with all Macans with LED headlights, regardless of E or V mode, using VAS-WiFi, with 70A power supply.
No issue with other Macans w/o LED at all. Regardless if 40.450 or lower or higher release.
#1116
QQ for the experts here - I have a 40.6 PIWIS 3 clone, is it possible in a MY2022 992 to bypass 'PIWIS Online' and change configuration under maintain vehicle data (specifically, enabling PSE)?
Thanks!
Thanks!
#1117
#1118
After I purchased my new old MacBook Pro 17" last week, I took the SSD, installed it, and when I opened the 37.250 VMware version of Piwis, I made the mistake of clicking "I Copied it" instead of "I Moved it" ![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
What can I do now? Delete the VM? I have the files on an external drive, but it's been so long that I installed it with help from a friend that I can't recall the steps. I'll read some notes to try to back track, but if someone can help guide me I'd appreciate it. After I clicked "I copied it", and opened the VM, Piwis has the Diagnostics and other buttons grayed out. By the time I remembered I should have opted for "I moved it", it was too late. I just hit enter and "I copied it" was already selected by default.
JB
JB
#1119
#1121
Well done! Can't beat a Mac... Alas, my Santa Rosa edition MBP was just too old even with an SSD and max out memory and I wasn't going to sacrifice my new M1 so I bit the bullet and went to the Dark Side... will I ever be forgiven...?![nono](https://rennlist.com/forums/graemlins/nono.gif)
But I do have a notebook running Windows XP SP2 for my VAG-COM a definite step up from WIndows 10 (apart from the USB support)
siberian
siberian
#1122
#1123
#1124
