Panamera 2010-Current
Received my new PIWIS III
Old 12-18-2021, 01:53 AM
  #886
rnlst_log
rnlst_log's Avatar
Originally Posted by runbuh
Good luck with the 992! I've been using both PIWIS and Launch for a year. Launch is faster and easier once you know where to go, but I don't think you'll be coding replacement parts to your car via the Launch (I could be wrong).
I've been trying to document things as I (or others) find them:
https://www.macanforum.com/threads/p...5#post-2627547
https://rennlist.com/forums/cayenne-...l#post17087929
I also feel like enabling the matrix headlights on my wife's Cayenne is gonna require a PIWIS (but I'm still looking).
Robert
Cayenne E3 need to have the matrix ready Headlight assy part, college in Seoul confirmed wiring is plug and play.
Vo Code 8JU, 8G4 to BCM, LED Headlight LEFT AND RIGHT, FAS_Front, AIRBAG, Kombi and ATM.
Old 12-20-2021, 03:49 PM
  #887
runbuh
runbuh's Avatar
I have the (US Market) Matrix headights.
Old 12-20-2021, 03:50 PM
  #888
runbuh
runbuh's Avatar
Originally Posted by siberian
I wonder if *** disable would work for 992 as listed for Macan and Cayenne... Many differences with the Macan and 992, impressive list, I'll need to go through it carefully.
Tomorrow (attempt) to change the tach ring from black (default) to whatever... stay tuned. It was either that or go to the mall shopping with TOWMBO... easy choice
siberian
I suspect the process will be closer to how it works on the Cayenne. Good luck.
Old 12-21-2021, 01:42 PM
  #889
rnlst_log
rnlst_log's Avatar
I believe it will be the same.
8JU/8IU and 8G4 vo code.
Old 12-21-2021, 01:53 PM
  #890
GoBlue!
GoBlue!'s Avatar
watching this closely. Would love to get the matrix on for my 971. Indy ship just needs the programming instructions
Old 12-27-2021, 03:45 AM
  #891
Fantasmos
Fantasmos's Avatar
Can anyone tell me how the key functions are configured? I played with the coding to retrofit the turbo spoiler and somehow my key stopped opening the trunk. Any idea where to look at?
Old 12-27-2021, 04:13 AM
  #892
don16
don16's Avatar
Originally Posted by sac02
Doh! I did mean .exe, it was not found.
Windows search found regedt32 in C:\Windows\System32, so I went to look for it, and I learned... This computer has no C drive! Lol, at least not visible in the "This PC" screen. The only drive shown is "DATA (E: )" 14.7GB free of 14.9GB. The other partitions (?) are hidden.
(edit: I tried to navigate to C: in explorer and got another error message, "This operation has been cancelled due to restrictions in effect on this computer. Please contact your system administrator.") Lol, can't even navigate/view the disk drive?
I tried to run diskmgmt, but it said that the snap in referenced has been restricted by my administrator.
I tried diskpart.exe and got a command line prompt type window, but no clue what to do with this info, lol.
All I bought from VXDAS was the SSD and dongle.
I supplied my own laptop.
All of the lockdown is done on the OS admin/group policy I think.
So I don't think that imaging the drive and installing in another computer will help.
Also I noticed other weird things locked out, like the ability to minimize or move windows. ***shrug
You need to boot laptop in to safe mode, then from there you will be able to access regedit, CMD etc. Beat way to sort the machine is in safe mode, create a new user and copy the software porsche registery keys from current user from locked down user to new user.
Old 12-27-2021, 05:47 AM
  #893
rnlst_log
rnlst_log's Avatar
Find the manual code value in rear end electronic, turn comfort open trunk using remote to active.
Old 12-27-2021, 05:50 AM
  #894
rnlst_log
rnlst_log's Avatar
The hints are here. Entrance is F7 menu, Maintenence Vehicle Data.
Old 12-27-2021, 07:09 AM
  #895
Fantasmos
Fantasmos's Avatar
There is no such coding. Checked the rear lid too. Do I need to enable engineering mode for that?
Old 12-27-2021, 08:34 AM
  #896
rnlst_log
rnlst_log's Avatar
Which panamera model is your?970 or 971?
Old 12-27-2021, 08:47 AM
  #897
Fantasmos
Fantasmos's Avatar
970.2
it was working before but I went through F7 to retrofit the rear spoiler. However, we disconnected the battery and the unit lost some coding. Brought everything back, only the lid doesn’t want to work with the key
Old 12-27-2021, 09:41 AM
  #898
rnlst_log
rnlst_log's Avatar
970.2
Do you have 4KE and 4E7 in the M numbers of vehicle data?
PM for more.
Old 12-27-2021, 11:21 AM
  #899
Fantasmos
Fantasmos's Avatar
I will check again and tell you. It now forgot that it has an aerokit and defaulted to a normal spoiler.. I hope I havent messed the module somehow
Old 12-27-2021, 08:55 PM
  #900
peterb77
peterb77's Avatar
You're right JB911,
I just got the PIWIS 3 with clone VCI from Belauto on an old Dell Precision 7710 that I hadn't used for a couple of years. It works great, I got the v38 + v40 with VAS6154 clone for $600 including delivery of the VCI. I just had to download the monstrously huge 76 Gb drive image and restore it to the laptop then Belauto remotely activated the software and VCI and even activated and downloaded the PET2 electronic parts catalog. This system covers everything up to 2020 Taycan. The system does start up in Russian region settings (including the keyboard) at first so you should probably know enough about Windows 8.1 to change the keyboard to English and then to change the region from Russian to whatever you need then your good to go. I get the impression Belauto is a VCI/OBD programmer the VCI clone is directly hooked into the operating system so PIWIS doesn't need to find or register a VCI (PTG3). He probably does the same with the Ferrari VCI.
Quick Reply: Received my new PIWIS III
