Android Auto Installed
#121
CarPlay remotely fitted
Another shoutout for Simaservic1108. Just completed CarPlay install on my 2017 Macan S. all done remotely on my drive with the excellent support of Simaservic1108. Can’t recommend him highly enough. Now have CarPlay which works faultlessly. Happy Boy
Nickshu (09-10-2022)
#122
Self install
For most of them offer the service for PCM4 are all public released patchs
for those of you don’t care about warranty, you all can do it by yourself. You don’t need anyone to do it remotely.
here Is the link below with instructions https://rennlist.com/forums/991/1049...s-real-27.html
however if you care about warranty risk and don’t want any fake FEC code being added into your head unit, then there is other way to do it
website: www.innovativesoftnz.com Contact us for discount code
Porsche PCM specialist
Skype:song8062
Email:info@innovativesoft.co.nz
Telegram: ClickHere / @innovative_soft
WhatsApp: +6421404548
To make order on website please contact us to get special discount coupon code for all forum members
Skype:song8062
#123
Telegram : Click here
Phone Number - Whatsapp : +381653086899
Email : simaservis1108@gmail.com
PCM Coding,Carplay & Android Auto Fullscreen,Maps update
#124
Hi,
I saw an option in PCM4 to display the number of GPS satellites currently connected.
Its one of the options you can change in the display instead of showing MPG, temp, distance travelled, av speed, etc etc
There's a long list of selectable options to display in the 'car' screen of the PCM.
Im assuming the field will only be selectable if GPS is already installed and functioning.
Just for reference mine was connected to 8 satellites.
#125
I am also not aware about such option in the Car menu
There‘s 2 ways I‘ve seen in the past:
- in GEM (green engineering menu)
- in Piwis under Actual Values, alternatively in an E Mode VAL
#126
rainer (10-03-2022)
#129
Car play and updated navigation?
Finally had android auto activated on my 2018 Macan GTS.
Always bugged me that it wasn't an option. Contacted Serbia Elektronike Koya on Facebook. All I need was an Ethernet to usb adapter (Jue130) and a SD card. Gave access with team viewer on an old laptop that never gets used and was up and running in no time.
#131
Film ware and unit
Thank you for responding!!
I have a PCM 3.1 and what I found regarding the film ware is the picture below.
If this is not what you need, can you point me in the right direction.
thank you Andy
thank you Andy
#132
#134
#135
