Macan 2014-Current
Sponsored by: HBI Auto
Macan Coding
Old May 29, 2023 | 10:11 AM
  #271
JUN6817's Avatar
JUN6817
Originally Posted by burlow
The menu dropdown in PIWIS should have several options, one being PDLS and another being PDLS+. select the latter one and go from there.
Today I try to do it,but not change 8G0 to 8G2...
not change automatic high beam light...
I have two big mistakes.
Firsrt I think do coding and change option menu on piwis,but it is not changing backside it is changing function..
Second I have no check on small car diplay "dym full beam"...
I think it is checked automatic on coding...it is for self..
Thank you Mr burlow!!
8G0→8G2
8JT(LED PDLS)→8JU(LED PDLS)
I check it and suceed ,it is not necceary for changing LED type...
perhaps it is only difference of code ...mechanical system is same parts.
Old May 31, 2023 | 01:02 PM
  #272
VAGfan's Avatar
VAGfan
FYI: Launch just updated the Porsche software to V24.15
Old Jun 3, 2023 | 10:09 AM
  #273
JUN6817's Avatar
JUN6817
please teach me.
macan 2022 upper
How to activate lane keep assist and traffic jam assist.
perhaps lane keep assist ,activate 6I1 but how to activate traffic jam assist?
Old Jun 6, 2023 | 04:49 PM
  #274
andoo's Avatar
andoo
3rd Gear
Question LKA activation
Originally Posted by JUN6817
please teach me.
macan 2022 upper
I'm in the same boat. I've ordered a 2023 macan with Lane Change Assist (LCA) but I forgot to add the LKA and traffic jam, that I actually needed. Called the Bellevue (WA) dealer and they told me they cannot added it post-production.
If anyone here has experience with this scenario, please advice if a software activation is the only thing needed, or it also requires some mechanical/hardware add-ons such as the steering wheel motor that will do the correction or modules as well.
Thank you!
Old Jun 6, 2023 | 04:54 PM
  #275
siberian's Avatar
siberian
I would assume some mechanical/electronic components are needed for the LKA in order to perform steering correction. I would venture that it's similar to the laser lights that you can set with PIWIS but if you don't have the hardware simply changing it in software won't do much.
As to traffic jam, that should IMHO be a coding issue unless in addition P has decided to charge a daily fee for using it.
GL and keep us posted
siberian
Old Jun 22, 2023 | 09:39 AM
  #276
JUN6817's Avatar
JUN6817
Lane keep and trafic jam coding
Hi rate to replay.
I think these options are the same Audi Q5.
SO I think it will be activated using manual coding on front camera and front endronic etc.
Because traffic jam option is included lane keep assist on USA macan option.
But I look up option list and I
decide option number start "only number" without alphabet....
I watch piwis3 on my macan gen 3 2023.
Lane keep assist option number is 6I1 and traffic jam assist is GJ1 !!!
I think two ways ,one using F7 automatic coding alt+a, another manual coding select ACC,front camera,combi,Lane change assist,power steering,front endtronics(BCM)..
I will try this weekend...
Please teach me differnce of automatic coding and maual coding...
Old Jun 22, 2023 | 02:15 PM
  #277
andoo's Avatar
andoo
3rd Gear
Please keep up posted!
Old Jun 24, 2023 | 12:16 PM
  #278
JUN6817's Avatar
JUN6817
Hi, I'm back.
Simply put.
LKA and TJA are activated.
I use piwis 3 on normal mode. It can be used in our language.
Changing option is not necessary to use on engineer mode.
upper 2021 macan,It has fontcamera and LWA(Lane warning assist)...
so we can activate PDLS to PDLS + ,LWA to LKA,LKA with TJA(traffic jam assist)
We can activate LKA ,we select front electronic ,instrument cluster,front camera,gateway and power steering and F12 and first step select piwis coding and second step maual coding and select option code 6I1 LKA.
If you have safety driving,and select GJ1 traffic jams at the same time.
two safety options will be activated after coding.
First I drive LKA only ,It is used for the upper 65km only..and not used under 60km.
But with TJA,If you almost drive automatically and safely under 65km ...more than my Audi Sq5 FLY.
Macan acc is not activated on 0km but Sq5 is activated on 0Km.
I like macan TJA more than SQ5,but on stop and go traffic,I like Sq5 using ACC.
If you have question,I answer as much as possible.
File Type: mov
Old Jun 24, 2023 | 04:25 PM
  #279
VAGfan's Avatar
VAGfan
Has anybody been able to code the rear hatch control module to enable closing the hatch with the remote fob? I found some "remote closing" parameters to change from "disabled" to "enabled", but it comes back with an error message saying that the coding change failed (the parameter stays set to "disabled").
Also, I have set the windows to all open and close ("comfort closing", "comfort opening") with the remote fob, but the sunroof comfort open and closing doesn't work with the windows. Anybody know what I have to do to make the sunroof remote opening and closing work?
Old Jun 24, 2023 | 05:50 PM
  #280
ChrisF's Avatar
ChrisF
@andoo My 2022 Macan S came optioned with LKA but not TJA. Also no ACC. Am I understanding correctly that both TJA and ACC could be enabled with PIWIS 3 coding?
Thanks!
Old Jun 24, 2023 | 11:12 PM
  #281
JUN6817's Avatar
JUN6817
Thanks!
your car has radar doom spot front of bumper?
In japan all range of macan have ACC.
If your car has acc,lwa,front camera,you can able to be activated all safety option.
Old Jun 28, 2023 | 09:33 AM
  #282
JUN6817's Avatar
JUN6817
front endtonics coding value
There is comfort sunroof ?
Old Jun 28, 2023 | 09:44 PM
  #283
steveo17's Avatar
steveo17
Originally Posted by ddsRepTarga4S
im down to team up with you.. Im In NJ but all over NY on an everyday basis
ever up in the Bergen county area? I have a 23 Macan I would like to have some basic stuff done on
Old Jun 29, 2023 | 12:34 AM
  #284
Beneil's Avatar
Beneil
Anyone in Bay area who can help by any chance?
Old Jun 29, 2023 | 12:38 AM
  #285
siberian's Avatar
siberian
Please post in the West Region Forum, thanks
siberian
