Sponsored by: APR
GT4 RS in the works? Rumors of a 4.0...
Old 02-23-2017, 03:30 AM
  #256
Jscho5
Jscho5's Avatar
How much should you expect in a dealer markup? or is it too early to tell?
also any information about production numbers?
Old 02-23-2017, 05:06 AM
  #257
mrd_spy
mrd_spy's Avatar
Originally Posted by drwuss
I want a pdk 400+ hp gt4.
its like being on mums net :-/
Old 02-24-2017, 05:33 PM
  #258
drwuss
drwuss's Avatar
i don't understand. educate me please.
Old 02-24-2017, 06:21 PM
  #259
RennOracle
RennOracle's Avatar
Originally Posted by Boris9119
Unless Porsche has a quantum change in philosophy, the GT4 will not trump the GT3 around the Nurburgring or any other racetrack, suggesting these rumours however fanciful, are just that, rumours.
They won't, the GT4 RS or the gt4 for the 718 will exist, AFTER the new 911 versions are in the market, at least the 991.2 GT3.
Then, have in mind that the 4.0 does not equal to the 4.0 in the RS / R. I really don't believe they will make a 4.0, in the 981, maybe in the 718, right now the GT4 RS is in a tricky position, because 911 gt3 and gt2 rs have to come out, at least the 991.2 and then there is the 718 platform.
Now, if it comes, the spec will be pretty obvious, x51 kit, lwfw (I would imagine) couple of carbon parts, canards.
Lets wait and see.
Old 02-25-2017, 09:58 PM
  #260
trebien
trebien's Avatar
Agreed, Porsche needs to keep differentiation between GT3 and GT4, just like the 718 versus 911... which they did with "4" cylinders versus "6" cylinders.
I would strongly doubt the GT4RS would get a 4.0 liter, even if detuned... or even if a "different" engine type/model than the GT3, which would have a more bespoke 4.0L engine.
My money is on the 3.8L X51 type of package, or a downsized 3.8L version of the new 4.0L in the GT3 - Porsche needs the displacement disparity. The existing 3.8L engine size in the GT4 has a lot of opportunity to make more power, and Porsche is not going to give the GT4 another 100HP for the RS version... so doesn't need to go to 4.0L, no matter how badly I would love to have it.
Old 02-25-2017, 10:16 PM
  #261
steve0827
steve0827's Avatar
Will cost less for 4.0, allowing for greater margins.
Doesn't make much business sense to restart production on an engine that is no longer used, for use in a lower production car.
I believe this still applies to the JIT-style production that Porsche uses.
Old 02-25-2017, 11:27 PM
  #262
trebien
trebien's Avatar
Relatively speaking, it would be easy for Porsche to make a 3.8L version of the new 4.0L in the GT3 - either different crank for shorter stroke, or smaller diameter pistons/sleeves.
Old 02-26-2017, 10:36 AM
  #263
RennOracle
RennOracle's Avatar
How would a 4.0 be cheaper than fitting the x51 kit from the parts catalog? What crankshaft would they get? The RS one? They would have to adapt the rest of the internals and maybe revised peripherals, and basically engineer a new engine, why do that, when they can just get already assembled 3.8 with x51 or just add the kit?
Old 02-26-2017, 10:43 AM
  #264
Randyc151
Randyc151's Avatar
They are already using a brand new designed 4.0, which is a spinoff of the old 3.8 with a stroke change to make 4.0. That means it may actually be lighter than the 3.8, and the design work has already been done too, so they need to spread out that engineering cost over more cars, too.
Old 02-26-2017, 10:53 AM
  #265
ZCPSnob
ZCPSnob's Avatar
For the record, I would be perfectly fine with an X51 3.8 along with the other tweaks the 718 got over the 981, as long as they changed the gearing so second gear wasn't 78mph...
Old 02-26-2017, 12:54 PM
  #266
morjo02
morjo02's Avatar
i would be happy if the 981 GT4 can obtain an additional 40-50hp - maybe someone will develop a new intake manifold. with out take headers, different exhaust, 82mm throttle body and an ECU tune maybe 40-50hp could be achievable or close.....
Old 03-04-2017, 08:36 PM
  #267
RennOracle
RennOracle's Avatar
What car is using that 4.0?
It's already achievable, hell, even more than 450. BGB has X51 package, 435 + Dundon headers and a decent tune alone put you on the +450 side, then you can stroke to a 4.0.
Old 03-04-2017, 10:43 PM
  #268
Randyc151
Randyc151's Avatar
The 2017 redesigned 911 RSR racecar is the first to use it, and it's moved to mid-engine for that car only. Porsche has already stated that this new engine will be used in upcoming models. Essentially, the 3.8 will be dying in favor of this new designed 4.0. The upcoming GT3 will also be using it.
Old 03-04-2017, 10:56 PM
  #269
DR1VEN
DR1VEN's Avatar
based on Porsche using the detuned 991S in the current GT4/Spyder to help keep the price down, it isn't a huge leap to guess (yes this is a guess) they will do the same for 982- ie detune another engine. NA Engines we are somewhat aware of that could be used in various states of tune:-
3.8 from GT4/Spyder/991.1S/991.1GTS
3.8 from 991.1GT3
4.0 from 991RS
4.0 from RSR (rumoured for 991.2 GT3)
3.8 from 991.1 GT3 has been a somewhat problematic engine and expensive to produce- probably not a good idea.
I would love to see the 3.8 in 991.1GTS tune with the power kit being made available for current GT4/Spyder. Definitely a possibility? But dunno if there is enough torque to keep it ahead of the upcoming 982GTS- esp as the 982S already matches the GT4 when on same rubber.
Easier to get torque from displacement so I think the more likely scenario is to detune the 4.0 from the RS. This gives the GT4/Spyder greater GT credibility- which the previous version lacked in the engine department and with PDK-S, it will be the typical kind of unobtanium that Porsche offers to make us buy new cars and justify any RS moniker.
While costwise a detuned RSR 4.0 could be very efficient to make, IMHO that would put the GT4/Spyder too close to 991.2 GT3. Just like 982 vs 991.2, I'd expect Porsche to have different engines in these cars to help distinguish them and justify the various price points.
whatever it is... expect it to make you want it... want it bad
Last edited by DR1VEN; 03-05-2017 at 12:24 AM. Reason: corrected typo... refs to NA3.8 in 991.2GTS was meant to be 991.1GTS
Old 03-04-2017, 11:56 PM
  #270
ExMB
ExMB's Avatar
Received 1,366 Likes on 831 Posts
Originally Posted by DR1VEN
3.8 from GT4/Spyder/991.1S/991.2GTS
I would love to see the 3.8 in 991.2GTS......
You do realize that the 991.2 GTS has a 3.0 twin turbo
Quick Reply: GT4 RS in the works? Rumors of a 4.0...
