Dundon GT4/Spyder Race Header Group Buy
#391
Well.....that's kind of hard to answer. The obvious situation could be a lean situation of the engine but the ECU adapts and you also have knock sensors so very remote doing damage to the engine by running these. You do risk having a few CELs so a Tune (via a solution like COBB AP) or DMS solution is a must if going this way. IMO...if I was going to go catless I would definitely do a Tune in order to extract the most and keep things on the safe side.
#392
With the COBB AP (which is what DMS uses) you can uninstall the whole thing and get the ECU back to stock in minutes for dealer visits...then when you get the car back you can install and upload the Tune again.
#393
If Porsche wants to see if the ECU was ever tuned, I'm sure they can tell.
#394
The ECU shows how many time it's been written over in the counter.
It's simple with the race headers. Anything like a catastrophic engine or gearbox failure get the home mechanic around the corner to rock up and out the factory headers back on before you trailer it to the dealer!
#396
That's true but at the dealer level you should be OK as that's what I do, actually recommended by the dealer.....would be great if someone from COBB or a dealer could chime in on this so we have the info from the source
#397
#398
#399
Can you elaborate on the experience you had please?
#400
Basic Sponsor
Porsche has been good with exhaust parts and most dealers are even willing to install.
Tunes are a completely different conversation.
Some of the Cobb AP's for porsche go through a back door and don't set a write counter.
The 981 Cobb AP isn't setup that way and sets a write counter, so the car would show that there has been a software flash on the ecu (both for modified and back to stock).
Cobb is working on a firmware enhancement to no trip a write counter, but no timeline has been provided.
Dundon Motorsports
Gig Harbor, WA
253-200-4454
jamie@dundonmotorsports.com
www.dundonmotorsports.com
Facebook.com/dundonmotorsports
Instagram @dundon_motorsports
Dundon Motorsports
Gig Harbor, WA
253-200-4454
#401
Basic Sponsor
The SDI9 is closed loop fueling at all loads and rpms. After driving the car it will adapt to the new fueling requirements. The tune helps to resolve these further, but the car does a decent job on it's own...
#402
But there is also risk with running aftermarket headers with cats - read about cats disintegrating and getting sucked back into the engine destroying it - link. Sure, can happen with stock cats, but guess warranty will cover that, but aftermarket ones, doubt Porsche will cover that.
#403
Basic Sponsor
#405
Basic Sponsor
HJS actually, tri-metallic cores straight from Germany
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
