strut tower failure
#556
It's dark right now. I'm sure there's damage to the rim but nothing obvious with a flaslight. There's a bulge on the tire. I never saw the pothole, dimly light highway. But yeah, it was deep for sure. I was traveling about 65 mph. I'm not particularly happy at the moment.
#557
Looks like Goldcrest Motorsports makes strut top mounts with bigger support plates that some wagered may help the issue. No affiliation, just came to know.
#558
Those aren't going to do anything to keep the strut tower from cracking and breaking off. You would need some type of brace that covers the entire tower and absorbs/diverts any stress to some other part of the car or weld additional material onto the tower. Simply bolting a plate to the top of the tower is pointless. It'd be like putting padding material on your back and letting a boxer punch you in the chest.
#559
The problem is in the car's structure,not in the plates. I'm no engineer,but those plates still attach to the car's structure just like the OEM ones...
Just look how flimsy that metal is in the strut tower! I can't believe Porsche went with that!
#560
Fools errand, at least in most states. Proving they they were negligent and had knowledge in advance of the pothole (and not an act of god, i.e. rain wash out) is difficult enough. Add to that the fact that most city/state/county governmental entities enjoy immunity....
One case was when there was an open saw-cut section of the freeway that had been temporarily soft-filled and chunked out. Herniated the sidewall.
Originally, the State DOT tried to pass it off on the sub-contractor. But a review of calendar dates indicated that the saw-cut section was under the responsibility of Caltrans at the time.
The other time was hitting a bridge/overpass joint that blew the right-front tire out. In both cases, they denied my initial claim... but my perseverance won out in the end. Took about 6 months to get a check from them for a new tire and alignment. It helped that I had contacted a Caltrans District Mgr to "oversee" my claim and go to bat for me.
#562
Ah, that sucks, sorry about that. If it's any consolation, I had a BMW with a cracked front strut hat. Rather than welding the top the shop replaced the whole mount, came out perfect. I know aluminum welding is different than steel but a good shop should be able to replace with new oem piece and be good as new.
#563
I've had the DOT in California pay for front tires on 2 occasions due to damaged tires on my VW R32.
#564
#565
Some state / municipalities will reimburse you for pothole damage. Your chances aren’t great but it’s worth a shot.
Here are 2 examples I found by simply Googling “ Will XXXX reimburse me for pothole damage “
https://www.idrivesafely.com/defensi...york-heres-how
https://www.attorneybrianwhite.com/w...icular-damage/
Best set of luck to the OP.
#566
PCNA has been useless on this issue. One member had a representative come out, who indicated that the damage was completely secondary to high impact from pot hole & not a mfg's defect.
A couple of members have been successful having their insurance cover the damage.
I'd pursue this as well with dept of highways.
#567
Location: On a pygmy pony over by the dental floss bush
#568
On the 992 forum stout posted pics of the much reinforced front strut towers of the 992. Porsche did nothing for the 991.1 991.2 981 or 718 but significantly beefed up for the 992.
Have we seen any cases with non GT cars? I wonder if there's anything to indicate that there's something about the front suspension or wheel/tire package (or both) that is making this an issue.
#569
#570
