strut tower failure
#496
BMW Strut tower distortion, cracking, & failures became enough of an issue that BMW engineers designed their own strut tower reinforcement plates (see above). Apparently this was an issue for E36, E46 M3's/ 3 series cars, & other models. BMW used light weight sheet metal in their strut tower construction, & deformation/deterioration occurred. These steel reinforcement plates were offered as part of the rough road package. BMW said the plates only had to be bolted on the underside of the strut tower mount, no bonding or welding required.
Deformed & cracked BMW strut tower above.
A Vorshlag tech describes how these things are used & modified if considering camber plates.
My car is currently stored in California & I live in Canada. Would anyone following this thread be willing/able to inspect & measure their GT4's strut tower underside to see if these may actually fit. If they fit flush & cover most of the underside surface, to walls of the hat, they at least will be stronger than the cast aluminum flat top.
#497
It may be a god idea to check the inside of the tower for cracks before and after a track day. Especially if you use the curbs or have an off.They would be easy to see. All you need to do is lift the wheel you dont really need to even remove the wheel. . I also checked under the shock rod dust cover for a bump stop, there isn't one!
Sorry for the orientation of the pictures i cant figure out how to rotate them .
carl
carl
Last edited by G-forceGT4; 11-21-2017 at 04:43 PM. Reason: inserting photos edit text
#499
I dont think that the plates by themselves do much at all. these are supposed to transfer the impact on the shock tower to another stiffening member as a strut bar of cage. The pictures that I have seen of failure show that the problem is not one of incomplete spread of the load of impact but of insufficient structural integrity of the shock tower to absorb the impact. If you can transfer some of that load on to some other place (such as an extension of the roll cage to the shock tower) from the top plate, then, you have a greater margin before failure.
Jpr
Jpr
#500
We just saw our first one come through here yesterday.
#503
#505
Thank you for sharing Buteo. It's a big repair on these cars.
Perhaps if this happens more often on other models as well, the impetus would be there, for our aftermarket friends to design something to prevent this potentially catastrophic suspension system failure.
#506
The clubsport reinforcing plate may be there for other reasons. One reason could be that it provides a “soft” load spreading function of the compressive forces from the nuts. If the aluminum shock tower is high strength, then it will generally be more brittle (less flex) than weaker material. Brittle materials do not like cracks that could form from stress concentrations coming from the nuts. The steel could be softer than the aluminum as well.
It’s hard to imagine, but when the car is in dynamic motion, these parts all flex to some extent. It gets very complicated. Without the benefit of having detailed CAD/FEA models, it is unlikely any of us will get beyond educated guesstimates as to what is going on.
The find that the GT4 underside steel plate is different/smaller than the Boxter's, and does not seem to extend to contact an area that was meant to serve as the contact "patch" is significant IMO.
Someone asked if the cross-strut tower reinforcement might help and two posters said no. I agree it does not directly address the cause of the failure, but, we really do not know. Anything that transfers/reduces the loading or maybe even changes the nature of the loading *could* help. Or, heck, could make it more susceptible. If you had the failure while you had the stiffener installed, you bet Porsche would cry foul.
If you had a strut tower failure AND had added the clubsport reinforcement, will Porsche have more reason to deny the claim – “you changed the design of the car.”
Joe-->any fallout from your insurance company with the mega claim? These things go onto your CLUE report, and even when they are no-fault ("NF" on the report), the company (and underwriters reading it) still use that information to determine risk.
#507
You’re not the only one
Has anyone seen the photos on Miglior Detailing Instagram page? the shock came straight through the strut tower. they also mention in the post that this is not the first they have seen...
I cant link the picture becuase it shows up on their IG on my phone, but when i look at their page on the web i cant see the picture..
account is migliordetailing
is the setup the same on the club sports as on our cars? why would this be happening?!
This happened to me today. Picked up car from dealership after having front passenger tire replaced for pothole damage a few months ago. Car drove fine after pothole. Today it was rattling from the get go after I picked it up. I pulled over and voila! Please if anyone has had this happen to them I’d like to know what Porsche did for you. These chassis is done and fixing it will probably wouldn’t the best option. Car has 5k mikes only, I’m devastated #GT4
#508
#510
