strut tower failure
#301
#302
Good question...
I believe X51 is shorter than stock, not sure how it compares to the GT4. However keep in mind that the 20" wheels and tires are larger OD. This raises the spindle height, reducing jounce clearance even at an identical ride height.
...On the other hand, the failure mode and $$,$$$ repair cost seen in multiple and nearly new GT4s is alarming after 50+ years of thousands of people lowering Porsches and putting hundreds of thousands of hard miles on their cars without widespread steel tower failures, no?
A friend and race car designer once mentioned a rule of thumb: design front suspension components with a 7x factor of safety- take the max corner weight the wheel is likely to see and multiply by 7, likely closing on 10k lbs for the GT4. However if you run out of travel even that's going to be wildly insufficient.
Lower any car improperly, even your 914, and you're going to get issues. The failures we're seeing look like a car that's been lowered improperly. I'd be shocked if Porsche engineers built that flaw in at stock ride height- this is 101 stuff and they are teaching graduate classes. However I suspect they didn't build in the margin that we (I'd argue correctly) expect, particularly since we did buy the ability to adjust ride-height.
If this theory proves correct then perhaps Porsche needs to issue a warning bulletin re ride height. I'm not sure that they fully understand that many here in the US will crank in more camber as step 1, possibly seriously compromising the design intent...
As it stands I worry that much of the standard setup advice (as seen on the sticky thread just below) may unwittingly be compromising the car and promoting this failure.
#303
Great write up and excellent points brought up. Well done!
Hearing your comments gave me the urge to try my Porsches and see if they feel or sound differently over bad roads......so I took rides earlier today back to back in 6 different Porsches I own over a very rough road close to home. I kept my speed steady around 50 mph and I tried to follow the same line. Without a question GT4 definitely sticks out of the bunch and especially with stock PASM module. The impact noises are much much loader and impact feels much harsher. I have installed DSC module a while back on GT4, but for this test I put back the original PASM module. Some of the impact noises sounded like hitting metal on metal and come through the shock towers and especially the back. Really awful sounds.
Interesting observation after reinstalling the DSC module back, I did one more run on the same road. Wow what a difference most of the noises if not all are gone and could not feel the harsher impacts, even when I selected the stiffer shock setting. GT4 felt like it was running on air suspension. Not sure why the DSC module is able to do that and not sure if it would even save the shock tower in a harsher wheel impact but at least it makes the GT4 sound & feel normal again, even if it is a false sense of security! Mark
Aluminum bicycle frames are stiff and you feel all the bumps in the road and are a harsh, noisy ride. While steel bicycle frames dampen and absorbs road shock well and are much more comfortable and quiet ride.
The GT4 cast aluminum is definitely at a disadvantage here over steel.
#304
I don't think it's a go/ no go question. The shock tower is the weak point- if you drive over a curb even with stock ride height it will fail. However the size of the impact the car can tolerate will be inversely proportional to ride height.
Good question...
It sounds like the ride height spec is +2/ -0mm. If true there's zero room to lower the car.
I'm not saying this isn't a design issue. I think it's a serious flaw. However the root cause may be that the GT4 doesn't have the camber and ride-height adjustability we all expect of a car with its design mission in mind. I don't see the aluminum shock tower itself as the flaw- that part is clearly sufficient in other applications. One could argue that steel would bend rather than break, but I'm not sure a bent chassis is all that much better...
Good question...
#305
Your description of the GT4 ride over bad roads attributed to the the strut tower to cast aluminum chassis mounting point is how a bicycles feels when comparing aluminum vs steel frames.
My wife couple of years ago went over a curb at +40 mph with our 2013 981 Boxster S which has the same exact design & dimensions as the GT4 and ended up severely damaging both wheels and tires and nothing happened to the frame or shock tower. After replacing the wheels and tires the car drove great for more than 2 years until we sold it which proves Pete theory.
If you also followed my earlier posts, I did mention the GT4 shock tower contact area with the upper shock mounting plate is roughly 30% smaller than standard 981 Boxsters or Cayman which results in yet higher stresses on the shock tower. In addition on the GT4 the shock centerline axis where the force is transmitted to the shock tower is offset toweard the back compared to other 981 Caymans and Boxters resulting in uneven loading distribution on the GT4 shock tower. So aside from bump travel concerns, there appears to be other design concerns than can add to this issue. But I think Pete theory makes so much sense, and there could be other contributing factors. Mark
#306
If the cast aluminum shock tower isn't a flaw, why did Porsche add 1.5 mm steel reinforcement plate to the shock tower for the 991 GT3 Cup and the GT4 Clubsport and it wasn't added to the 996 GT3 Cup or the 997 GT3 Cup with the steel shock tower. If the cast alumimum shock tower isn't a flaw maybe it's just weaker and needs reinforcement.
I think the steel reinforcement plates added as these cars have probably shorter bump travel compared to the street cars and they also see much more abuse on track. It will be a nice addition to the street cars. Mark
#307
As i theorized in a previous post. With The lower the ride height they didnt want to use a shorter bodied shock so to have the travel they eliminated the bump stop. Now the shock bottoms out on the brittle cast alum tower with no dampening of the blow and impact. What could possibly go wrong?? carl
#308
The race cars use much higher spring rates (and triple the chassis stiffness/ strength with a cage) so they likely require (and can use, without twisting the frame) stronger parts.
It looks fairly straightforward to design a part to reinforce this area, but if the shock is bottoming as I suspect you'll just be moving the problem. Of course if that makes the weak link something that fails gracefully and is easier to repair that might be ok, but I'd rather address the root cause...
This might be a good application for crushable foam aluminum or similar replaceable energy absorbing structures if you could fit them.
#309
I agree, about the weight saving, as it is minimal and especially if they allow for the same safety factor as steel. With the added thickness to compensate for the lower strength, the net weight savings is minimal. Not sure though about the cost savings being so significant as we experimented ourselves of making our large centrifugal pumps out of Aluminum vs steel, and yes there was a cost savings but it was not significant as we have to add additional thickness to compensate for the lower strength, but the castings sure look great, but at higher volume I guess it adds up. I guess the corrosion resistance would be an added value for Porsche with the Aluminum. Mark
#310
Location: On a pygmy pony over by the dental floss bush
#312
Again I'm not sure was it in fact from a GT4 shock. If Joe could diasect his that would be great. Carl
#313
I'm still waiting on the new shock tower part to arrive at the dealer, was delayed last week "...due to the holidays", per the parts guy. If it doesn't arrive in a week or so, I will go to my plan C to obtain one. I don't have access to the 3D scanner until after the new year anyway....
Having real data on the shock/spring/force/travel as mentioned in Petevb's earlier post would be useful for the FEA analysis I'm working towards.
#314
If you encounter an object on the road while traveling at 60 mph and the suspension can't articulate/ comply to clear without lifting the car itself the forces get astronomical. That's true regardless of the bump rubber package. And in this case the chassis stiffness of the modern cars works against it- the older frames would happily flex for some additional compliance.
#315
https://rennlist.com/forums/gt4/9483...l#post13807855
