i ddi 3 days on COTA and another day at MSR... lol.. i guess i should change it out but i still have lots of rubber left.. still feels like there is grip =) ill do one more local track
Yeah, enjoy them, they're still fun down to bald. I think Joe either broke 2 mins at Thunderhill or did 2 flat with tires that had almost no tread.
By the way, if there is no rain it's good to swap left/right if you only run CCW or CW tracks and not a mix of CCW and CW
Thill 2:00 can be done with worn tires
Sub 2:00 needs tires with good tread on them.
I’ve found that once a section of the tire is near flat, whether it be the outer edge or the center tread, times start to suffer. Other parts of the tire may look fine, but if a section is nearly bald, then count on slower times.
For me usually 3 days are good. Days 4 or 5 will be slower.
Have you guys been able to get a set of the re71rs in stock 20” sizes recently? I ordered from Tirerack, but the tires aren’t currently available. Any other sources?
Have you guys been able to get a set of the re71rs in stock 20 sizes recently? I ordered from Tirerack, but the tires aren t currently available. Any other sources?
Alex
I tried discount tire and was told that they are now tirerack exclusive. My last set came from discount tire and was cheaper than tirerack.
My order of RE71 in stock 20 size is still on backorder with no ETA from tirerack. Does anyone have different info on the ETA?
Spoke to TR on phone today. We are screwed. Nothing even being produced as was mentioned in an earlier post I believe. I was at my mechanic today scrounging some of my old used tires
