Sponsored by: APR
0Q Pure White - journal
Old 11-25-2016, 11:23 AM
  #46
d00d
d00d's Avatar
Originally Posted by Mech33
I recommend checking your filter. I ran this setup for a few thousand miles and I ended up having oil everywhere near where I put the filter. But I do track the car occasionally so that may be a factor. I went back to the stock configuration.
...and that's the point of this modification.
Oil mist that escapes the filter would otherwise enter the intake, and some of it would become carbon on the intake valves and surrounding area.
The filter is intended to keep dirt out, not to keep oil mist in.
If it's dripping out of the filter instead of just misting, a catch can would be appropriate to be a good track citizen.
Keep in mind that a minute amount of oil is also blown past the piston rings and out the exhaust.
Originally Posted by Alan C.
What did you do for headers? My Dundons should be here next Tuesday.
I had DMS send them to Swain for coating, looking forward to using them!
I'll probably use the following to secure them, seems to be more effective than wiring them together.
Item Number: 6910 (12) 8mm-1.25x25mm bolts 6pt DHH (need 18, order 2 for 24);
http://store.stage8.com/p/6910-gm-2-...on=recommended
Old 11-25-2016, 02:06 PM
  #47
Alan C.
Alan C.'s Avatar
Received 1,042 Likes on 535 Posts
I thought about asking Dundon to ship the headers to Swain but didn't. Ultimately would have been quicker.
Old 11-25-2016, 02:22 PM
  #48
Mech33
Mech33's Avatar
A good effective reasonably sized catch can is hard to find. Let me know if you know of a good one that could fit under the car.
Old 11-25-2016, 06:36 PM
  #49
d00d
d00d's Avatar
I like the ProVent 200, it's 8.7" tall and can be angled up to 45°;
https://www.mann-hummel.com/fileadmi...nt_en_2013.pdf
https://www.youtube.com/watch?v=nz2eBsSwwQs
http://forums.tdiclub.com/showthread.php?p=846480
http://www.audizine.com/forum/showth...-Can-Reference
Old 11-25-2016, 11:52 PM
  #50
r553
r553's Avatar
I'm going to order a JEGS 555-52205 AIR OIL SEPARATOR KIT. Will report back after install.
Old 11-27-2016, 06:44 PM
  #51
d00d
d00d's Avatar
DMS is on it's way...
Old 12-24-2016, 12:49 PM
  #52
r553
r553's Avatar
Today I installed a small JEGS catch can at the end of the direct vent mod hose.
Old 12-25-2016, 12:40 AM
  #53
d00d
d00d's Avatar
Nice!
Didn't realize how compact it is.
Old 12-25-2016, 11:48 PM
  #54
d00d
d00d's Avatar
Mele Kalikimaka
Name:  IMG_1302 1 edit.jpg
Old 05-06-2017, 06:10 PM
  #55
d00d
d00d's Avatar
I installed Dundon race headers with Swain Tech White Lightning ceramic coating, using Stage 8 locking fasteners, and added the Dundon COBB tune.
Seat of the pants dynamometer shows welcome torque and horsepower gains, and the power band doesn’t have the weird dips it had before.
Idle is louder, and starting around 3K RPM it gets noticeably louder than before.
After a spirited run there is a lot less heat streaming out of the wheel wells, from lack of the heat sink catalysts, as well as the coating.
I’m back in love with my GT4, although I have to admit to eyeing the 580-2.
https://rennlist.com/forums/gt4/9346...ts-update.html
https://rennlist.com/forums/gt4/9495...group-buy.html
http://www.dundonmotorsports.com/981-gt4-spyder
http://swaintech.com/race-coatings/r...aust-coatings/
Using Stage 8 locking fasteners prevent the bolts from loosening.
When a torqued bolt was oriented so that the finger wasn’t close to the tube, I chose to tighten the bolt slightly so that it could pick up a better orientation on the bolt head, but one could loosen slightly instead.
http://www.stage8.com/gm.html
http://store.stage8.com/p/6910-gm-2-...-v6-header-kit
Two bolts on each middle tube need longer fingers.
Fill out the Stage 8 web form asking for four longer fingers, or figure out which replacement finger package is the right one to buy.
The most important tool for this project is a long flat head screw driver to pry the O2 sensor wire clips out of the attachment points, as there’s no way to get enough leverage with your fingers.
Name:  IMG_1482 1 copy.JPG
Old 05-06-2017, 08:46 PM
  #56
Crazy Eddie
Crazy Eddie's Avatar
Attachment 1162617
Attachment 1162618
Attachment 1162619
Nice and clean !!
Old 05-07-2017, 11:18 AM
  #57
Tioga120
Tioga120's Avatar
Well done d00d. Thanks for the details and links and would like to hear more after you run it more.
Old 05-07-2017, 11:46 AM
  #58
ShakeNBake
ShakeNBake's Avatar
very nice!
Old 05-07-2017, 05:47 PM
  #59
Jamie@dundonmotorsports
Basic Sponsor
Jamie@dundonmotorsports's Avatar
Beautiful work.
Make sure to check the flange to the stock exhaust bolts after a few hundred miles, They'll need to be retightened to ensure no leaks!
Old 05-07-2017, 10:58 PM
  #60
Alan C.
Alan C.'s Avatar
If I hadn't used studs I'd try that. Nice install.
Quick Reply: 0Q Pure White - journal
