Sponsored by: APR
0Q Pure White - journal
Old 09-02-2020, 09:57 AM
  #256
TDT
TDT's Avatar
Originally Posted by d00d
After a lot of grinding and fitting, have the slant cut tips attached.
I've got a set of these.... mates to PSE or FVD/M&M.. Interchangable tips - slash cut @ OEM angle or turndown.
Old 09-02-2020, 10:06 AM
  #257
fusionrace
fusionrace's Avatar
Originally Posted by Snowy999
wray at BGB supplies. cusd3-4k for a kit - intake, cables, starter, new intake boot, throttle body. When i contacted them in Jan they had not yet fitted and tuned to a GT4. they told me the whole kit inc starter needed no PIWIS work but would need a cobb protuner to sort it.
Group buy anyone?
Old 09-02-2020, 10:07 AM
  #258
user1029
user1029's Avatar
looks like it is more cost effective than Dundon intake runner ($3700) + IPD/GT3 TB ($1300) combo
Old 09-02-2020, 11:20 AM
  #259
Snowy999
Snowy999's Avatar
The runners and ipd keep appearing in the classifieds as people cycle to the 718 gt4. you may be able to go Dundon for a fair few dollars less?
Snowy
Old 09-02-2020, 11:33 AM
  #260
user1029
user1029's Avatar
Already have dundon intake runners and IPD plenum and debating whether to go club sport
Old 09-02-2020, 12:08 PM
  #261
TDT
TDT's Avatar
If you already have made the investment in the Dundon solution, i don't know if you gain anything by swapping to Clubsport - unless you can get all your money back on the Dundon kit.... or at least enough to cover the bill of all the CS parts.
Power delivery will likely become different to what you have now... you may like it or not.... because the difference in volumetric dimensions and velocity of the plenum and runner between the two solutions will be different.
Old 09-02-2020, 12:19 PM
  #262
d00d
d00d's Avatar
That may not fit the 2 1/2" OD FVD, stock is 2 1/4" OD.
Yep, As Snowy says - in the US, BGB will be able to supply - the intake parts come from Porsche Motorsport - so PMNA in North America.
The other parts are combination of normal OEM Porsche parts... starter motor can be surprisingly expensive... but best if you can get the whole setup up as a package.
I already had the TB, and bought the starter from Amazon, part numbers and link in post 121.
Old 09-02-2020, 12:37 PM
  #263
TDT
TDT's Avatar
Ah ok, yep.
As it is, I haven't actually had them fitted yet - I've been to 2 track events in the last couple weeks - one was unsilenced anyway, the other was a 105db, but didn't have any issues so far.... running with valves open.
Have another day @ Silverstone GP next week so will try to get readings then.
@d00d Have you had the car on the dyno and/or tuned yet?
@BGB Motorsports are currently installing the 718 CS intake onto a 981 Clubsport, and also recenty did an Agate Grey 981 GT4 - so will be interesting to see what they make of it.
Old 09-03-2020, 12:33 PM
  #264
d00d
d00d's Avatar
I'll be getting a COBB tune from BGB, but probably won't put it on a dyno, as I don't have a baseline to compare to.
TDT (09-03-2020)
Old 09-09-2020, 04:58 PM
  #265
d00d
d00d's Avatar
After spirited acceleration up through the gears I backed off the throttle, then tried to get on the throttle again but didn't get any, eventually it came back.
The Sport button auto blip functionality wasn't working from that point on until I started the car again.
This happened twice, but on a leisurely trip it was fine, so I'm assuming it was due to the engine shifting on its mounts and pressing the sensor further into the cover pad.
The off throttle weirdness was due to the header tune not knowing about the different intake.
Back to the stock tune and no problem, but probably less power, will eventually be using a BGB tune for the intake.
Old 09-09-2020, 05:53 PM
  #266
TDT
TDT's Avatar
Custom/Pro-Tune is really required for this intake to work properly.
My specialist in the UK spent a lot of time with the car on the dyno to get it right..... with just that hardware installed, stock map - we saw that we lost a load of torque at lower revs even vs stock- but then it eventually made a made a big gain in Peak HP at the top of the rev range - fuelling was all over the place.
Once we got the map and fuelling corrected - it shows to be a meaningful upgrade.
Old 09-12-2020, 12:12 AM
  #267
d00d
d00d's Avatar
Thanks TDT, good information.
Had Eric at Lou's Custom Exhaust and Auto Repair (227 Willow St, Manchester, NH 03103) do the final welds, excellent work as usual.
Old 09-12-2020, 10:02 PM
  #268
Snip's
Snip's's Avatar
Never liked JB Weld...
Tig weld or go home...
Old 09-13-2020, 10:29 AM
  #269
d00d
d00d's Avatar
JB Weld may have been successful if completely filling the void between, but was useful in positioning for the TIG welds.
Old 06-12-2021, 09:15 PM
  #270
d00d
d00d's Avatar
Selling my GT4.
I'm not driving it enough to keep, 7,508 miles in over five years.
https://rennlist.com/forums/market/1255584
Quick Reply: 0Q Pure White - journal
