Sponsored by: APR
Orthojoe's GT4 track thread and ramblings
Old 01-03-2018, 05:57 PM
  #1246
Shockwave
Shockwave's Avatar
Watched your video of the 991.2 GT3.
Initial Impressions?
Old 01-03-2018, 09:59 PM
  #1247
orthojoe
orthojoe's Avatar
https://rennlist.com/forums/991-gt3-...s-awesome.html
skip to post 116 if you want to start with track impressions.
Old 01-12-2018, 05:59 PM
  #1248
zsapphire7
zsapphire7's Avatar
Question about your rear wheel setup with OZ. Is it the Leggera HLT et50 19x11"? Tirerack is telling me that there are brake caliper clearance issues for the gt4 but i find it hard to believe since you are running them...
Old 01-12-2018, 06:22 PM
  #1249
brad@tirerack.com
Former Vendor
brad@tirerack.com's Avatar
To run the 11" wheel you need to change the end links, and possibly run a small spacer depending on alignment setup to make them work.
Old 01-12-2018, 07:12 PM
  #1250
Bill Lehman
Bill Lehman's Avatar
I found the brake caliper "interference" on the front calipers using 19" OZ. It wasn't metal to metal but lack of sufficient clearance. I ran the 19 x 10 on the rear without issues but did have Tarett Toe Links. Sold the OZ and replaced them with CCW. No issues with the CCW but the price more than doubles.
Old 01-12-2018, 07:32 PM
  #1251
brad@tirerack.com
Former Vendor
The front OZ's don't hit the calipers.
Wheel weights will have to placed on the inner edge of the wheel to prevent the calipers from knocking them off. There is also the possibility that rocks could get between the caliper and wheel, scoring them. It's a great wheel for the money, but it is very tight.
Old 01-12-2018, 08:03 PM
  #1252
Crazy Eddie
Crazy Eddie's Avatar
I thought I remember reading that Joe had an issue with the rear brake line poss rubbing ?
I think it was corrected with a little elbow grease. i.e. bending the line out of the way ??
Let Joe comment ....
Old 01-12-2018, 09:34 PM
  #1253
Alan C.
Alan C.'s Avatar
Received 1,051 Likes on 540 Posts
I had a rear brake line issue with rubbing and a set of Spiegler lines corrected the issue.
Old 01-12-2018, 10:10 PM
  #1254
orthojoe
orthojoe's Avatar
Here is what I recall:
Front wheels clear the calipers, but the wheel weights need to placed away from the calipers. Also, the front brake ducts need to be trimmed or they will hit the wheel weights.
The rear wheels require aftermarket toe links or spacers. Not all aftermarket toe links will work. I know that the tpc ones will not work. Also, one of the electrical lines that control the parking brakes can rub on the wheel, so it needs to be bent over.
Old 01-15-2018, 11:45 AM
  #1255
GeoJoe
GeoJoe's Avatar
Joe speaks the truth. Coincidentally I took my OZ wheels for a tire swap and they mounted weights in the barrels a little too close to the caliper. If the car is jacked up without any load, it may clear fine and you think you're ok. I got black flagged on the first lap and the marshal says "we hear a rotational tick tick tick coming from your car." There's nothing like taking an razor blade to your $100k car to shave a little off the brake duct. All good and I went back out to have a blast!
Old 01-18-2018, 07:33 AM
  #1256
jmartpr
jmartpr's Avatar
Received 1,477 Likes on 918 Posts
Had the same problem (OEM 20" wheels) but you just need to play with the line a bit and bend a little the metal tab....so far it's good, no more rubbing problems.
Old 08-18-2022, 04:41 PM
  #1257
vantage
vantage's Avatar
It is my understanding that you will run out of threads in the front OEM tie rods if you run aggressive camber.
Is there a common level of camber at which the OEM tie rods run out of threads? Perhaps that varies by car, but I'm only planning to run -2.5 degrees right now, so wondering if I need the front tie rods.
Old 08-18-2022, 05:19 PM
  #1258
jmartpr
jmartpr's Avatar
Above -3 deg.
vantage (08-18-2022)
Quick Reply: Orthojoe's GT4 track thread and ramblings
