Sponsored by: APR
Orthojoe's GT4 track thread and ramblings
Old 07-10-2017, 10:07 PM
  #1186
ML///
ML///'s Avatar
What's the cost for the wheel bearings? Same price for all four?
Old 07-10-2017, 10:23 PM
  #1187
orthojoe
orthojoe's Avatar
All 4 bearings are the same part. About $140 each
Old 07-11-2017, 10:23 PM
  #1188
okie981
okie981's Avatar
Location: On a pygmy pony over by the dental floss bush
Originally Posted by orthojoe
Has anyone had any failed wheel bearings? All FOUR of mine have gone bad and need to be replaced already. GT3 did over 60 track days with no wheel bearing issues, but the rears were replaced under track maintenance guidelines. I'm really starting to wonder about the durability of the GT4. My buddy's boxster spyder had 3 times the amount of track time my GT4 does and the wheel bearings never went bad.
Sounds like an opportunity for some aftermarket parts. Wonder if anyone is offering upgraded replacement wheel bearings?
Old 07-12-2017, 12:43 AM
  #1189
orthojoe
orthojoe's Avatar
Turns out the bearing parts are the same as the gt3, which have been solid for me. Maybe I got a bad batch or hit something harder than I thought. That being said, I've haven't been off track yet in the gt4, but I have been off track multiple time in the gt3 though....
Old 07-12-2017, 01:53 AM
  #1190
DC640
DC640's Avatar
You may be right joe on possible bad batch. Plus you aren't really using sticky tires (Hoosier for example) that puts extra stress on parts. It's mainly heat and load that kills those bearings - having said that, it is odd and surprising all 4 corners are bad all at once!! Is it a significant wobbling on the hub ?
Old 07-12-2017, 11:17 AM
  #1191
orthojoe
orthojoe's Avatar
Yup. Re71r and cup2 only. One of the front hubs is pretty bad wobble. The rest are subtle but definitely need to be replaced for track use.
Old 07-13-2017, 01:26 PM
  #1192
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Yeah, heat is the killer - hub temps are incredibly hot...take an on-track laser measure...you will be stunned
Old 07-13-2017, 02:12 PM
  #1193
okie981
okie981's Avatar
Thinking about this some more after reading Joe's earlier posts about the bearing failures and how his GT3 took way more track days with no bearing issues, could there be something about Joe's GT4 that cause higher hub temps compared to his GT3 for the same track use? Maybe air flow to the rotors is different? Different size wheel's and/or tires? Seems like higher temps would be more likely than all 4 bearings having some type of sub-standard manufacturing quality.
Old 07-14-2017, 09:43 PM
  #1194
bluvan
bluvan's Avatar
8500 miles 9 track days at beginner pace. Front left bearing was reported showing first sign of wear with minimal movement by indie shop doing a pca tech inspection. I was kinda hoping it was a fluke and definitely hoping it was warranty, now all hopes are dashed...
Old 07-17-2017, 06:39 PM
  #1195
vantage
vantage's Avatar
Hi Joe,
What is this meter in front of your GT3 tach?
At first I thought it was a shift light, but that doesn't seem to be the case. Is it g correlated?
Old 07-17-2017, 07:11 PM
  #1196
orthojoe
orthojoe's Avatar
So it turns out the front bearings were fine. Just a loose lower control arm bolt which caused the play. The rears bearings did have to be replaced.
Originally Posted by vantage
Hi Joe,
Good eyes!
It is G correlated.
I've been asked to test this device:
https://www.apextrackcoach.com/
I'll do a write up on it after I spend some more time with it and let you guys know. Talk to Clark at Apex performance if you want more details for now. It's a cool device.
Old 07-17-2017, 07:13 PM
  #1197
Alan C.
Alan C.'s Avatar
Received 1,042 Likes on 535 Posts
I've read about this. Looks interesting
Old 07-17-2017, 08:25 PM
  #1198
vantage
vantage's Avatar
Thanks Joe. Ah the friction circle. I hit max g under braking and just before I start unwinding the steering, but not so much in between!
Old 07-18-2017, 12:55 AM
  #1199
Mech33
Mech33's Avatar
Wow there is some serious marking BS going on on that website, and ubiquitous use of the "machine learning" buzz word.
Basically the device is just keeping track of how much total acceleration vector your car is capable of and then shows you how close you're getting to it at each instant on the track.
Fun concept, but is it actually useful, Joe? You should be able to feel the same thing, and if I couldn't feel it, I don't think I'd trust this little device's "machine learning" predictions no matter how many black and white engineering drawings they copy and paste on their website graphics.
Good eyes!
It is G correlated.
Old 07-18-2017, 01:14 AM
  #1200
orthojoe
orthojoe's Avatar
Spoken like a true engineer! Lol! From what I gather, it looks like a live Gsum meter just like I use in my videos. Useful tool, but not everyone knows how to use math channels in rs2. Anyways, I'll do a more in depth write up after I spend some more time with it on Sunday. There are some cool things about it. You're welcome to try it out as well. We'll see who can log the highest 'score'.
Quick Reply: Orthojoe's GT4 track thread and ramblings
