Orthojoe's GT4 track thread and ramblings
#241
Are you talking about the rear tires of the GT3? We've been running higher pressures on that car in the rear (34-35psi hot) and it still hasnt helped
#242
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,294 Likes
#243
Yes. It does this two ways. First, as soon as you begin to press the brake pedal, the DSC will send the signal to the shocks to firm up the front. Brake pressure is one of our inputs gathered through the CAN line. Secondly, as soon as that longitudinal g-force begins to shift toward the front of the car, the DSC is also going to account for this in the g-table. This is just one of many ways the DSC controller helps to improve vehicle stability and chassis control.
#244
What difference would it make since you have a totally independent unit controlling the dampers? The main ECU has lost control at this point and is a passenger when it come to the suspension. Unless you are just worried about dash lights.
#245
#246
I'd be more inclined this DSC system was providing more than just placebo if there was more quantitative data on exactly what it was doing vs. stock on the same track and same situations with a pro driver,band the resulting impact.
My data I mean actual raw suspension data coming into the DSC module get it is processing, and what it is doing as a result. For example, this would show how DSC has the dampers configured in transient throughout a specific turn transition, overlayed vs stock, and the resulting suspension travel difference and sector time difference, etc.
That is, PROVE this is actually doing something more intelligent than Porsche is already. In general I am very skeptical of small "engineering" teams hacking things like this from the outside without all the original tools and capabilities that the designers had and ending up in something that isn't worse, let alone better.
Testimonials from people driving the car before and after just aren't reliable tools... would you trust a butt dyno?
#247
#248
Premium Sponsor
For those who would like to see video of DSC shock dyno demo and output data on a car-
DSC demo on Roehrig Shock Dyno-
DSC data on GT3 Cup race car (Courtesy of CRex)-
Here is CRex's full post of the Data Visualization in the 997 GT2/GT3 section-
https://rennlist.com/forums/997-gt2-...isualized.html
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
TPC Racing stats:
#249
I'd be more inclined this DSC system was providing more than just placebo if there was more quantitative data on exactly what it was doing vs. stock on the same track and same situations with a pro driver,band the resulting impact. My data I mean actual raw suspension data coming into the DSC module get it is processing, and what it is doing as a result. For example, this would show how DSC has the dampers configured in transient throughout a specific turn transition, overlayed vs stock, and the resulting suspension travel difference and sector time difference, etc. That is, PROVE this is actually doing something more intelligent than Porsche is already. In general I am very skeptical of small "engineering" teams hacking things like this from the outside without all the original tools and capabilities that the designers had and ending up in something that isn't worse, let alone better. Testimonials from people driving the car before and after just aren't reliable tools... would you trust a butt dyno?
#250
No, the DSC won't throw any PASM codes. Between my old Cayman R (with stand-alone DSC) and my current GT4, I have never gotten a PASM- or suspension-related error code.
The only thing I've noticed as far as "unusual" electronic conditions in the car is that you can't access the DSC box via the Durametric Pro software -- the Durametric just says it can't access that component and acts like PASM isn't installed. And honestly, that's not really a surprise, since DSC isn't PASM. Also, I've checked all the other systems that are accessible with Durametric Pro, and there are no codes anywhere related to the suspension or suspension controller that I can find.
#251
We haven't heard much from orthojoe lately so I thought I'd post a few ramblings of my own after finally taking my GT4 to the track for the first time this past weekend.
I can't recall people complaining about the gas gauge but I was constantly getting low fuel warnings when I still had half a tank. Annoying! Does anyone use their SoloDL to look at fuel level? Curious if the same data that causes the low fuel warning in the dash also causes the fuel level on the Solo to be skewed.
The oem brake pads suck. Not much bite and not much feel. They wear quickly too. There is so much swept area on this car that slowing the car down was never a problem in spite of the crummy pads. Really awesome they put these brakes on this car!!
Huge rear grip on the car. I took the car to a short, tight track with one sharp, steeply uphill corner that becomes a showcase for every car's lack of rear grip and/or lack of a good LSD. The GT4 did just fine here. Surprisingly easy to put the power down.
There doesn't appear to be a huge difference in the level or the threshold at which PSM and traction control intervene when they are on or off. I liked that. Might as well leave everything off. Others here agree?
I thought I was good at heel and toe. Who needs auto-blip, right? I DO!!! Geez, it's fantastic. Makes me feel like I'm cheating.
Coming from my fully race-prepped 987 Cayman the GT4 felt like it was very softly sprung. You really feel the weight of the car moving around under heavy braking and in abrupt transitions. That certainly makes running over the curbing more of an option at some tracks. But, personally, I think the car is too soft for serious track duty. Stiffer springs, a better alignment and corner balancing, and some R compound tires would make this car a beast.
Michelin Sport Cup 2's are not Hoosiers. If I was trailering to and from track events I would only run R7’s.
SO glad I got most of the car wrapped with Xpel. My windshield took a beating from stone chips after one track day. Typical of Porsche glass. Very glad the paint had some protection.
The track had a scale and I weighed my car. 2,990 net of fuel. They had a gas pump next to the scale so I filled it up, weighed it and then subtracted 100 lbs for fuel.
Orthojoe I've missed your ramblings! You really need to get to the track more often.
#252
Orthojoe I've missed your ramblings! You really need to get to the track more often.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
#253
Glad to see all the GT4s at the track.
#255
Yes, .2RS (I put 12k miles on it over 3 years)...I have received a lot of "Bu1lsh1t" sentiment from my brothers in the 997 GT3 forum....but it's the truth from my perspective. It's not faster....but close. Everyone is the Stig. I posted a video of Andy Lally in a .2RS, me in a .2RS, and me in a GT4...all similar tires and about the same lap time, and still....peanut gallery.
RS is more fun, but I ran out of patience with the maintenance - it's a bear when they get older.
