Sponsored by: APR
Australian GT4s
Old 10-18-2016, 11:37 PM
  #676
Bardman
Bardman's Avatar
Originally Posted by Snowman.
I still can't believe you got rid of them Brad. I love mine!
I am just happy that they have gone to a good home.
Originally Posted by Charliekay
No longer in transit.
Glad they arrived ok. Hope you enjoy them.
Old 10-18-2016, 11:38 PM
  #677
Bardman
Bardman's Avatar
BTW - cross posting this thread for those who might be interested in decals. Now is the time to jump if you are thinking about doing this at some point:
https://rennlist.com/forums/gt4/9586...-in-quick.html
I'm happy to vouch for these guys.
Old 10-19-2016, 04:00 AM
  #678
nzskater
nzskater's Avatar
Originally Posted by No Heel No Toe
32 - 33 or so hot
about 24 cold
This is the official word from Michelin, and based on experience I'd say it's bang on.
Old 10-19-2016, 06:17 AM
  #679
O5C4R
O5C4R's Avatar
^ looks like i was bang on too
Old 10-20-2016, 08:40 PM
  #680
DR1VEN
DR1VEN's Avatar
Thanks chaps... much appreciated!
Old 10-20-2016, 10:15 PM
  #681
roders
roders's Avatar
Hrms.... tempted to put some PS Cup2's on my Macan for the track.
Just about finished off the OE PZero's after the last track session and 20,000Kms.
Original OEM Sizes were 265/45/R20 & 295/40/R20.
Given the sizes the PSC2's come in, would 265/35/R20 with 295/30/R20 still fit happily? Width would be the same just a slightly smaller diameter? Am I right??
Old 10-21-2016, 12:57 AM
  #682
Snowman.
Snowman.'s Avatar
Correct Rod.
Just be aware though that reducing your rolling OD will make your speedo out.
Old 10-21-2016, 01:17 AM
  #683
roders
roders's Avatar
Will it effect the gearing?
Someone said it might stuff up the Sport settings when not using the manual paddles as it is PDK?
Old 10-21-2016, 04:06 AM
  #684
DR1VEN
DR1VEN's Avatar
Wow, that's basically putting tires designed for the Cayman on the Macan. I'd carefully check the load ratings. Is also going to look a little weird. Speedo almost 9% out on the rears. Usual recommendation is no more than 3%. I'd say no.
Old 10-21-2016, 04:13 AM
  #685
roders
roders's Avatar
Thanks for the calculations, 7+% is a bit too much of a difference.
The Macan is already matching times of the Cayman/Boxster's on the track
Cargraphics lowering module dropped it about 10mm which helps in the corners.
Back to the drawing board for new tires and brakes......
Old 11-01-2016, 08:34 AM
  #686
.dee
.dee's Avatar
anyone going to Burrows day at EC next week???
Old 11-06-2016, 06:04 AM
  #687
Warwick Morris
Warwick Morris's Avatar
Hi .dee. I'll be there. I've not posted here before. Had the car since Sept but have hardly used it; a couple of drives and 500kms to run it in easily. Finally got the FIA paper work for the front section of the Porsche cage (which cost $9K!) and submitted the CAMS log book application. I'll do Burrows on Wednesday and I am doing Bathurst later in the month in the weekend regularity. I'm running a race car in the completion sprint on the Thurs and Fri. Mine is guards red. Hope to see you there.
Old 11-06-2016, 06:20 AM
  #688
O5C4R
O5C4R's Avatar
Hi Warwick, is the porsche cage a bolt in cage or weld in, seems very expensive for a bolt in, i am getting a full bolt in cage done for targa and only just starting to get quotes hopefully next week
Old 11-06-2016, 09:38 AM
  #689
.dee
.dee's Avatar
500k's since September you are doing good! mine's on 200 since August, just have not had the time to muck around with it.
its now at PR tech for a proper set up, i'm busy in the morning but will be there lunch time onwards...
will say hi if i run into you.
Old 11-06-2016, 09:20 PM
  #690
Warwick Morris
Default Bolt In
it's bolt in and the carpets have cuts already in them to fit it. $9k was AUD and suspect about US$5k over there as PCA take a big lend of us. I wanted to have a full club sport spec car with the OEM cage as I intend to keep the car a lng time and it may add value in 10 year's time (probably won't of course). It is a full current FIA cage though and passes GT4 homolgation and looks plenty strong. I may never actually fit it.
Quick Reply: Australian GT4s
