E/SIM Racing For discussion and info on iRacing, SIMs etc.
Rennlist iRacing thread
Old 03-17-2014, 01:22 AM
  #3886
Gator_86_951
Spell Checker
Gator_86_951's Avatar
This car is so-so at Road Atlanta, but I am looking forward to it. A good set would help. This car is particularly difficult in the uphill section after T1 compared to other cars....I think.,
Old 03-17-2014, 09:05 AM
  #3887
pmason
pmason's Avatar
I want to get better at the setup part, for you guys that have been creating the different setups can you share your approach. I've read the setup guides, etc, and know there is any number of things that can change the understeer/oversteer but I have never seen what I might call a decision tree or thought process, which do you try first, second, third, etc. Assume the first goal is to get the car as low as possible to get a low CoG, you want to get a good corner balance which I'm not sure would be for this car 45/55?, but then when do you do next?
Old 03-17-2014, 10:38 AM
  #3888
abqautoxer
abqautoxer's Avatar
Getting a good baseline is the hardest part IMO. I always just use someone elses and then modify it based on what I do with real cars. Try to determine what the car needs on what part of the corner. (entry, steady state, exit) and if its low or high speed corners (possible aero changes). Springs and bars for steady state, shocks for entry/exit with a bit of a bar change if putting down power on exit is a problem. Not sure its the best though, I think Justin, Julian, and Ted seem to do a better job of setup than I do.
Old 03-17-2014, 11:03 AM
  #3889
HoBoJoe
HoBoJoe's Avatar
Right now I'm using Edmund's setup for Road Atlanta and it was better (for me) then the one I pulled from the forums. With Edmund's blessing I'll post it up through dropbox for those who didn't make the practice session.
Old 03-17-2014, 11:41 AM
  #3890
JustinL
JustinL's Avatar
I do the same thing Tom. Grab a baseline and then tweak it. The biggest things I've learned are:
1. Strive for comfort and consistency and not speed. If I can make the car do what I want, then the speed will come. I always lose time trying to trim wing out of an already loose car etc.
2. Make one change at a time and give the setup a fair shot.
3. Don't judge it on the first couple corners, but do a few laps before assessing it.
4. I don't understand the tire temperatures in the sim and thus almost never touch pressures or camber.
Old 03-17-2014, 12:16 PM
  #3891
abqautoxer
abqautoxer's Avatar
Agreed. No matter what time someone else can do in a setup. I give it 1 warm up lap and then lean on it for 5 laps solid. If I can't control it, I change it or move on. I've tried taking wing out of the RUF and it just makes it too lose in the high speed corners so I find I'm always at 8 or more, usually around 10 and the gurney.
I don't touch camber much but I do touch rear toe quite a bit along with the shocks. Stupid autocrosser stock class habits.
Old 03-17-2014, 12:34 PM
  #3892
87944turbo
87944turbo's Avatar
I had a pretty good race too last night. Some stuff started making sense in my head and I picked up the pace a lot. Watching the replay I realized I punted Bobby I believe, going into Gurney Bend. Sorry about that.
Yep that was me. No worries, certainly knew it wasn't intentional. Car didn't have any real damage and I really didn't even loose that much time if I remember correctly.
Enjoyed the practice last night. Lots of good driving and situational awareness. A far cry from rookie street stock racing!
Old 03-17-2014, 07:17 PM
  #3893
JustinL
JustinL's Avatar
Here is the beginning of the schedule for next season. It will be starting with a Tech track, so make sure you download it from the Tech track section. I've only driven it in testing a couple of times and that race is going to be a mess. COTA should be out in time, but if not I'll flip it a week later. The question is what should we fill the blanks in with. Should I reuse tracks from last season or press on with new tracks? Are we staying in North America or should we take a trip abroad? Should I double up on COTA? Do we even want to try LRP again?
1 9-Apr-14 Long Beach
2 16-Apr-14
3 23-Apr-14 LRP (Do we really want to try this again?)
4 30-Apr-14 COTA (if available)
5 7-May-14
6 14-May-14
7 21-May-14
8 28-May-14 Watkins Glen Boot
9 4-Jun-14 Kansas Speedway (road course)
10 11-Jun-14
11 18-Jun-14 VIR
12 25-Jun-14 Watkins Glen (Classic Boot maybe?)
13 2-Jul-14
Old 03-17-2014, 08:09 PM
  #3894
Anthony Nguyen
Anthony Nguyen's Avatar
Double up on cora sounds good to me. Anyone up for a practice session tonight?
Old 03-17-2014, 08:10 PM
  #3895
abqautoxer
abqautoxer's Avatar
I'd run a practice around 9pm EST.
Daytona is always good.
Indy
Okayama Long
I feel bad asking people to buy too many new tracks. I'm all for recycling those that worked well.
Old 03-17-2014, 08:19 PM
  #3896
HoBoJoe
HoBoJoe's Avatar
I would like to do Lime Rock again, it would be nice to see how far we have come as a group. Also, I just really like that track...
Also I think doing some of the free tracks would be a good idea. I don't believe we ran Summit or Okayama, I know summit is small but it just makes it more interesting.
Old 03-17-2014, 09:00 PM
  #3897
Indy Rev
Indy Rev's Avatar
Barber, Indy, Daytona, Zandvoort, Silverstone, Brands Hatch....
Old 03-17-2014, 09:52 PM
  #3898
Indy Rev
Indy Rev's Avatar
just hosted pass Rennlist
Old 03-17-2014, 10:41 PM
  #3899
911racer
911racer's Avatar
There is a password ? Can I get in?
Ed
Old 03-17-2014, 10:48 PM
  #3900
HoBoJoe
HoBoJoe's Avatar
Anyone can get in, under hosted sessions it's named rennlist.
Quick Reply: Rennlist iRacing thread
