DIY - 991 DIY info for the 991
991.2 spark plug DIY for 3 year maintenance
Old 01-25-2021, 05:38 PM
Tier1Terrier
Tier1Terrier's Avatar
I just want to say THANK YOU to @polobai as this was a much needed topic (for the 991.2 specifically). While you do a nice job with the explanation and photos, I'm not sure I feel very encouraged to tackle this one as a DIY. Maybe that'll change. Dealer wants 900 and indy wants 700 to do this all-inclusive (parts & labor). Seems like getting that one tricky plug is what scares me the most.
Old 01-25-2021, 05:42 PM
Keadog
Keadog's Avatar
Received 1,100 Likes on 659 Posts
Originally Posted by asellus
ah, beat me to it. Was gonna do this in the next month or so. I'll still be making a video more than likely.
thanks for the info!
I doubt I would ever attempt this myself but would follow both threads!
Old 01-25-2021, 05:48 PM
B Russ
B Russ's Avatar
Yup not tryin it here either
Old 01-25-2021, 06:00 PM
polobai
polobai's Avatar
Received 1,125 Likes on 670 Posts
So far, not that bad (only did drivers side) but would rate it more on the technical side that the laborous side. In all, would probably rate it a 6.5 out of 10 but you should be confident with turning some wrenches before diving in and have a good assortment of tools. The most careful part for this spark plug change (and any) would be to ensure the new plugs are installed properly and not cross threaded. On the 991.2 it makes it a bit harder as the spark plug is not at zero degrees in the hole-but angled about 20 degrees downward. Honestly, I think the $900 charge at the dealer is a fair charge considering the amount of work and time it could take. I would say it would take a solid 3-4 hours for a tech on a two post lift with the correct Porsche specialty tools. Comparatively speaking, this is easier to do than a header change on the 991.2. If you can tackle that, you can tackle this.
SFZ GT3 (02-02-2021)
Old 01-25-2021, 06:01 PM
mammothcar1
mammothcar1's Avatar
Excellent, thank you for the great write up, looking forward to the rest.
Have you replaced the engine airfilter yet on your T?
Old 01-25-2021, 06:21 PM
polobai
polobai's Avatar
Yes, I have. Alot more stuff has to be removed for that to be done-I tackled it when I did the Tial inlets about 8 months back. In retrospec, I should have done the plugs then as the intercoolers, cages and hoses were out and everything was easily accessible. It all works out in the end-now you guys can see how to do it without having to pull all that stuff off.
Back when replacing the air filter and inlets. Perfect opportunity to get the spark plugs done.
Old 01-25-2021, 06:25 PM
mammothcar1
Nice write up, thanks again.
polobai (01-25-2021)
Old 01-25-2021, 08:28 PM
r00t61
r00t61's Avatar
Originally Posted by Joec500
Makes sense, Turbo's probably introduce more heat and pressure.
Interestingly, the maintenance interval for the air filter has increased:
On my 991.1 C4S, it was every 2 years/20,000 mi
On my 991.2 TT, it's every 4 years/40,000 mi
Old 01-25-2021, 08:39 PM
Speed2k
Speed2k's Avatar
Thank-you! While I'm pretty handy and have a ton of tools, this doesn't look like something that I want to attempt.
Old 01-25-2021, 09:21 PM
polobai
polobai's Avatar
I am sure you can do it. The biggest fear is just diving in to take it apart. These cars come apart quickly and go back together pretty easy (minus the rear suspension).
Old 01-25-2021, 09:30 PM
ngamountains
ngamountains's Avatar
Good to hear from someone who has done it, looking at your pic of changing the engine air filter. I just had to replace a fuel line on my daughter’s VW Golf Mk7 that got chewed through by a rodent, and it looked like it could be assembled by a five-year old, but getting it apart was a nightmare.
Old 01-25-2021, 11:57 PM
911-TOUR
911-TOUR's Avatar
FYI - I think the 991.2 Base/S/T/GTS plug interval is 30K miles / 4 years - whichever comes first.
Old 01-26-2021, 12:21 AM
polobai
polobai's Avatar
Thanks, I have heard conflicting intervals so figured it would be best to do it early and be safe. Got the coils off the passenger side tonight-similar to drivers side where the rear coil is buried deep. Some fanangling got it out.
Turbo inlet and heat shield removed to gain access to the coils
Rear coil torx bolt...had to put the wobble extensions to use
Old 01-26-2021, 12:24 AM
polobai
polobai's Avatar
And the coils are out. On this side there was not much play in the connector wires as they were tied into a loom that has a ground near each coil. Take your time and they will come out without removing the ground wire.
Ready to pull the plugs
Coils-seem to be in good shape.
vanlieremead (01-26-2021)
Old 01-26-2021, 12:53 AM
vanlieremead
vanlieremead's Avatar
I wouldn’t do it initially by myself. If I had a “Porsche Buddy” where we could work together, and learn along the way, then perhaps. Luckily, I’m at 7500 mile so I should be good for a while.
Quick Reply: 991.2 spark plug DIY for 3 year maintenance
